Results 1 to 10 of 10
Thread: '85 250R CDI vs. '86 250R CDI ?
    Miami,Fla.(305)
    808
    I'm curious to know why the '86 CDI is alot larger than the '85 CDI. Also, does the '86 CDI allow a few 100 more RPM or are they the same? -
    (I thought I've heard that before-probably wrong).- Anyway, is the '86 better in any way? Does it have a secondary backup circuit or something?- There should be some explanation for the difference in size when everything else is really the same (yr. vs yr.). It must have been redesigned for a reason is what I'm saying- I Don't think the '85 is more faulty than the '86 right?? (I know about the plug being different). Does anyone know? Sorry, if its a dumb question.
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    MN
    3,263
    I would have to look at the wiring diagrams for both but i think they are basically the same and have the rev limiter in them at the same RPM, etc.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    na
    5,702
    No they ain't the same, and they do not have different RPM limits..
    The 85 has a single round connector and the 86 runs a 2 plug connector that will swap with all the TRX's 250R's..Also be careful of what you buy..The 350X will plug into the 86 and up 250R harness's but wont run right.The only benefit of the 86 and up is there is alot more out ther if you need a replacement,
    Proudly NOT a member of
    "Team on the Teat"
    Jan 2011
    Choctaw, OK
    2,755
    Ya for some reason Honda engineers decided to split off the two wires for the engine kill circuit. The larger CDI body was to accomodate the additional plug.
    Blossvale NY
    4,563
    Hey Mosh, by any chance would you be able to post a side by side pic of the 2? I know my R is an '85, but it sounds like I have the CDI you describe as being the '86. Sounds like at some point my R may have been swapped over to an '86 harness..
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    MN
    3,263
    Yep i just looked at the manuals to confirm, the 86 switched to the new style dual connector type. Other than that, they are basically the same internally however.
    Blossvale NY
    4,563
    Quote Originally Posted by kb0nly View Post
    Well, I definitely have an '86 harness in my '85 then... Or at least parts of it. My CDI is the dual connector type. One plug has (I believe) 4 wires and the other plug has 2. Definitely 2 seperate plugs though....
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    na
    5,702
    No sorry..the one thing I am thin on is 250R cdi's. all the ones I have are mounted.
    "Team on the Teat"
    MN
    3,263
    Most likely someone did that to get it running again when the older style CDI, thats harder to find, died on it.
    Blossvale NY
    4,563
    [QUOTE=Mosh;1153521]No sorry..the one thing I am thin on is 250R cdi's. all the ones I have are mounted.[/Qoute
    Ok, thanks anyway Mosh.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
