Results 1 to 10 of 10
Thread: propane instead of acetailine for cutting steel?
    Mar 2005
    overton, PA
    5,257
    ok people when using a set of propane/acetaline/oxygen torches does anyone know where the regulators should be set and how to adjust for propane i am usign a #1 propane tip and was told 6 psi on the propane and 30 psi on the oxygen?? what do you guys use to cut 1/4-1/2 inch steel?????
    Scootertrash's Avatar
    In the sticks
    4,638
    Spelling Nazi says it's "acetylene"
    Try this:
    http://lmgtfy.com/?q=propane+cutting+torch+settings
    Oct 2007
    Grosse Tete, LA
    3,441
    The last time this little, overly educated goat checked, grammar rules only pertain to spelling when the placement of letters affects the structure of the sentence.
    Back to sleep (the pronoun, adverb, and verb are all implied).
    Mar 2005
    overton, PA
    5,257
    i googled it and hjave tried difrent adjustments and pressures but wanted to ask for personal experiances
    In the sticks
    4,638
    Quote Originally Posted by The Goat View Post
    OP corrected to Spelling Nazi
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,246
    one guy asking questions 4 posts about SPELLING???? lame!!!
    to answer your question,,, do to cut that thick with propane you might need to go way bigger on the tip size,, propane has very little btu output compared to accetelene... it takes alot longer to use propane,, in production the time is not worth the cost savings!!!
    Mar 2005
    overton, PA
    5,257
    thank you casey, i tried a #2 top today and got my mixes right and it cute well enough for what i am doing , i made a 16 foot car trailer in 7 hours today now just deckign and wiring and then axles and go figure i was doign it before with a stihl ts400 demo saw with metal blades lol
    timex69 is offline Just Too Addicted Arm chair racerJust too addicted
    Sep 2003
    Saskatchewan
    485
    fuel gas 5-7 psi and oxygen 30-40 psi
    Nov 2004
    Waterloo IL
    2,701
    I worked at a metal / machine / weld shop for 3.5, we used propylene. I couldn't tell the difference with that vs acetylene.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Nov 2004
    Waterloo IL
    2,701
    Also what does overly educated mean? Are you a doctor, a lawyer, and an astronaut?
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
