I just recently pulled my 85 250SX frame out from under my work bench and began cleaning it up and painting it. Then "it" happened. I rescued a brand new turbo package from hitting the dumpster. Didn't know what I was going to do with it at first, then a co-worker put the bug in my ear, "Put it on that 3-wheeler you are building." I thought about it, and I finally figured it out just a few minutes ago. If I completely remove the air box, I can mount it in that area. The exhaust weaves back into the frame at that point, and can exit there also. The air horn outlet would be aiming directly at the carb, and I can run a remote air filter to supply it. Have a TRX350 RH crankcase cover will built in oil cooler on my 250 now, so I can direct the oil feed line to the turbo, then from it to the oil cooler, then back to the engine. Comments?
