Results 1 to 9 of 9
Thread: 1985 ATC 250r EATS gas...
    Afrothunderkat's Avatar
    Afrothunderkat is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2011
    Richmond NH
    336
    Took my trike on a 3-4 hour ride today, and I ran out of gas. Twice.
    First time, ran out of gas from full tank to 1/4 in 3 hours. Second time was 1/4 tank refill and it ran out in 30 minutes. Carb does not leak, and the jets are stock. I was ridding with my buddy on another 85 250r, he had half a tank when mine was empty. We both ride aggressive and his trike is much more explosive than mine. Why do I go through so much gas?
    Stock jetting THAT rich? My plug is black. Im running 32:1.
    For engine mods, trike has boysen reeds and a FMF full system
    2003 RM 250 ::: 1985 ATC 250R ::: 1986 ATC 250ES
    Past Trikes: 1985 YTM 225DX ::: 1984 200s ::: 1985 YTM200
    Past Bikes: 1987 KX80BW ::: 2002 TT-R 125L ::: 2000 RM 125
    Quote Originally Posted by Tri-ZNate View Post
    Talking about the build quality, I got their exhaust and economy muffler and it fits together like tossing a hot dog down a hall way with nothing provided to take up the slop. Best $200 ever spent
    Sarnia, Ontario, Canada
    3,415
    Not having the same experience as other members particularly on the 2 strokes I can't give the direct answer you are asking for..then again I don't think anyone can.
    But then the answer is in your question I believe..stock jetting on a modded engine setup, and your plug is giving you the clue.
    Time to start jetting experiments. I'm sure there are a few in here with some main jet numbers to start with.
    I guess you rather run rich than lean..lots more troubles than running out of gas come of that.
    Good luck with your experimenting!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Mexico
    9,014
    Sounds like you're running rich and/or may need new rings, but still 2 hours out of a tank running hard seems ok. Keep in mind these trikes were made with closed circuit racing in mind, not a day long enduros, the range is likely not that great on a stock tank. I don't know the 250R well (haven't ridden one since 1986) or how large your tank is, but I'm guessing there are guys on here that get worse mileage than you are. BTW, your buddy with the better performing trike is likely jetted closer to right than you are and like I mentioned, may have a better sealing engine. Time for a compression test and then if its good, a muffler packing and some jet tuning. I know you said your carb is not leaking, but you want to be sure the ends of the drain lines are dry. You may be leaking intermittently if you have a bad needle/seat. Lots of easy things to check. Have fun.
    Aug 2010
    Southern Oregon Coast
    932
    3-4 hours of riding on the dunes is about what I get on my R before I have to refuel. I'm running a DG pipe with a fmf silencer and a K&N in the air box, lid off. When you open these things up to breath, they get thirsty.
    Miami,Fla.(305)
    808
    Lots of factors & variables involved. Riding conditions/terrain/mods/tuning/wear/rider -ect. I always go thru 4 gallons in about 5-6 hrs of almost non stop riding.
    ('85 ATC 250R).
    ^^^^^^^^EL Camexican^^^^^^^^good advice/tips
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    Marty is offline Just Too Addicted Arm chair racerJust too addicted
    Nov 2007
    Mesa, Az
    644
    When I had my 1985 ATC 250R it had 190lbs of compression, stock carb, ESR pipe, carbontech HT reeds, and if I got 2 hours of seat time at Glamis dunes I was happy. But ATC ate fuel but it didn't help it had paddles and I was 220lbs and in sand and my 1985 ATC 250R was dyno tuned>
    May 2011
    The Granite State
    914
    so im the buddy...just throwing it in to give a better idea. My trike isnt on steriods or anything but is fully piped, .20 over, v-force 3's and duncan racing carb.
    Something is def going on with afro's b/c when hes about out i have 1/3 of a tank or so left and mine likes to piss out the overflow TOO!
    I think hes not quite tuned in but I also think it has a lot to do with the stock 85 carb (round slide). Thats alot of gass difference, and we are about the same weight. Can anybody chime in that has replaced theirs from round to flat? Any noticable difference in gas consumption?
    Windham, Ohio
    147
    My 85 250R is a very thirsty beast. Pound for pound much worse than my 454 powered chevy 3500HD. I can get about 2hrs out of a tank.
    Blossvale NY
    4,563
    Quote Originally Posted by Super350 View Post
    Well, before I did my 350 cyl kit I was running a stock cylinder that was .050" over. No porting. Aftermarket reeds, torque spacer, high comp head gasket, 38mm PWK/AS carb, full FMF Fatty exhuast.
    I ride seasonal gravel roads, long straights and sweeping curves. I spend quite a bit of time cruising in 5th or 6th playing around hitting the pipe often. That setup would get me 25-35 mpg. I only know because I ride with some 4x4 quads that have speedo/odos and was curious to know. It translated to roughly 2 or more gallons burned in about 3-4 hours actual seat time depending on how addicted to the happy lever I would be on any given day and how fast we are riding.
    Since going to the mid-top ported 350 with most of that appropriate intake/exhaust components (bout the only thing I'm lacking is boring my 38mm carb to 40.5) my MPG has gone down noticeably. I seem to be doing right around 20 mpg give or take.
    If you have a worn topend that could cause excessive fuel consumption....
    I concur with all of the previous advice posted.
    It really does depend on the rider and his/her style, gearing, rider weight. So many variables. All you can really do is make sure everything is up to snuff with your engine and jetting and let the chips all where they may.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
