Trikes Currently Owned
~1985 Honda Big Red 250ES ATC
~1986 Honda 250SX ATC
Kind of cool, doesnt look bad. I myself would prefer full fenders over race cuts.
Currently Own:
1985 ATC 250sx
1986 ATC 350x
Projects/Parts machines:
1980 ATC 185S
88 CR frame that nobody corrected the rake on when converted.
I like the grab bar.
1985 Honda 250r x2
1986 Honda 250r
1986 Honda 250sx
1985 Honda 250sx x2
1985 Honda 350x x2
1986 Honda 350x
1984 Honda 125m x4
1984 Honda atc 70
Yamaha tri zinger
Yamaha 4 zinger
Brap braaaap
You say aggressive, I say incorrect.
Right rake and stance= a bike that not only goes good straight, it can also turn. Not only that, but the bottom of the frame and pipe are not going to contact the ground if you bottom the suspension. I bet you can sit that frame right on the ground before the suspension bottoms.
Wrong rake and "aggressive" stance= a bike that does nothing better than a properly set up bike and looks bent doing it. The "aggressive" stance is a matter of opinion, and I don't agree with it. Basically, a poorly done conversion.
I agree with fabiodriven. If they went through all that trouble to make a trike, then it should be done right, but to each their own.
I said it makes it look aggressive, never said it would ride correctly or that I would do it to an offroad vehicle. I've raked out a few harleys and an old GS, generally ruins the turning radius. It's hard enough to make a decent turn with a solid rear axle, nevermind with incorrect rake.
Edit: What is the stock rake and trail on one of those?
