Results 1 to 15 of 17
Thread: my big red is crying
    Jul 2012
    spring
    9
    Month ago I got my first trike. Br250es and it rocks. Couple weeks ago I changed oil which it needed bad. While I took it muddin last week I noticed in low gear and first that it started to whine I didn't notice it before the oil change bit idk what's up. Any clues for me? Thanks
    Jul 2012
    Douglas, Ma.
    124
    MIllion dollar question: what oil did you use?
    Jul 2012
    spring
    9
    Rotella 1540. I was told it would work fine since it doesn't have a clutch
    Jan 2011
    Choctaw, OK
    2,755
    Actually your Big Red has two clutches. One centrifical clutch and one regular wet clutch. Get the Rotella out of it and replace it with regular ol 10W-30 conventional oil. Be sure to replace the oil filter too.
    Dec 2010
    845
    10-40 is what i use
    MY TRIKES! :
    1- 85 250r NOS engine
    1- 1985 350x
    1- 82 250r + Parts
    1- 86 250es Big Red
    1- 85 200x
    2- 84 200es Big Red
    1- 84 200M !!MINTY!!
    1- 73 Atc 70 (project)
    MY Snowmobile's!!
    1999 Polaris Indy 440
    1999 Ski-Doo 583
    1993 Polaris Indy 500
    My Dirt Bike
    1986 Dr100
    fingerlakesny
    2,834
    ya, i use 10 w 40 also. never had a problem.
    Aug 2012
    Pembine, Wi
    20
    Yeah dont go to wallmart and buy cheap oil, get to your motorsports place and buy somthing good, no synthetic somthing like maxima or any high quality atv oil. Its worth it in the long run, Ive recked several machines trying to save money on oil.
    1984 Honda 200x (real nice)
    1983 Honda 185s (almost new)
    1985 honda 200s (parts)
    Sep 2011
    oswego ny
    70
    or clutch saver works good too
    Jul 2012
    spring
    9
    Ok. Will do. I read alot of ppl use 1040 but 1540 was closest I had at work and was told by buddy that used to work at a bike shop 1540 would be ok. I will definitely swap oil and filter. Don't wanna kill my first trike. Thanks guys.
    Jul 2012
    spring
    9
    Quick q....any links or help on how to change filter?
    Tucson
    1,652
    O boy, there is a reason for a manual, read it follow it if your not sure about anything. and never rely on anyone that you dont trust to tell you what oil to use, your manual is your best friend!
    Aug 2012
    Fremont Nebraska
    23
    Isn't the filter on the drain plug? I can't remember
    Tucson
    1,652
    No there is actually a filter on the motor.
    Tucson
    1,652
    Jan 2011
    Choctaw, OK
    2,755
    Here's a link to the manual. Its in Chapt 2 (Maintenance)
    http://www.oscarmayer.net/atc/manuals/
