Ok...I was riding my Tri Z and everything was going fine. Trike started when cold with the choke on since it was pretty cold outside. Then as it warmed up I turned off the choke. Ran great but I never went full throttle for very long or generally over 1/2 throttle.
When I start going over well over 1/2 throttle or really just nail it full throttle for about 15 seconds it acts like its running out of gas. Almost as if the fuel value has been turned to off and the gas is emptying out of the carb.
My thought is that the fuel pump is working but its just not working good enough. (i.e., not enough flow to replace the increased gas being used)
The strange thing is that after this happened about 5 times or so the bike would only run with the choke ON....and at this point it was fully warmed up. If I turned the choke off then it ran really rough and acts like it wants to stall.
Keep in mind this is not all the time. Only after it dies after really hard acceleration for an extended period of time. I have not done any carb modifications and dont have any new parts requiring jetting.
So is this the fuel pump or the carb? When I start it after it has been sitting it runs fine with no choke when warmed up. It can run all day (normally with no choke) no problem at up to 1/2 throttle or even at full throttle but not for more than a couple seconds. If I go over for very long its acts like its running out of gas.
Thanks in advance everyone!!
Darius
