does anyone know of one being offered now? or would ther be any interest if there was a kit available? I looked and all I could find were modified drums and some way too much fab work for a bolt on type of guy. Thanks in advance for any input.
That would be a nice addition. I would consider that a good mod if it were affordable that is.
Russ J in SW PA
83 Honda 200 (fishing and hunting "rig")
83 Honda 185 (parts)
95 Polaris Xplorer 300 4x4 (WIP)
hmmmmmm i have an idea hehehehehe le tme do soem research on this.
Is there much need for it? The stock shoes fit bigger 3-wheelers and some motorcycles so its kind of overkill for a 70. With a nice drum and new shoes Mine will lock up the rear wheels with ease on hard packed dirt with me on it (210lbs). I'd say it might even lock the tires up on the road but I've never tried it. I'm not saying a rear disc wouldn't be nice, just not something I personally would spend money on.
08 Outlaw 525s
07 CRF70
04 Harley FLHRCI
04 TRX90
03 XR650R
03 400EX- XR650R engine
02 XR100R
01 Banshee
00 XR50R
00 XR70R
99 PW50
99 JR50
96,95 Sportsman 400
95 Xplorer 400
94 Indy XLT
87 Trail Boss
86,86,86,86,86 Scrambler
86 TRX70 x2
85 ATC350X
85,84 ATC250R
85 Red Tecate
85 LT50 x2
84 XR500R
84,84,84,84,83,82,80,79 ATC70
82,79 XL500R
83 ALT50
79,78,77,77,76 XT/TT500
76,75,74 XL70
72,71,71,71 SL70
72 Harley FX
72,71,70,70,70,70,70 CT70H
72 SL100
70,69 Z50
do I really need to explain the advantages? Less fade,better wet performance,no adjusting. longer pad life. You said the key words "with a nice drum and new shoes" These machines are 27+ years old and finding a brake drum that is actually not past its recomended wear can be difficult. If someone has an all original 70 this obviously wouldn't be for them but it seems alot of the 70's have been modified with bigger engines ect. and a modern brake system may be benificial to these modded machines.
Isn't there a company that already sells a disc set up for a 70???
I have seen one for the front but it is not bolt on at all and having first hand experiance with it I wouldn't recommend it. That kit is just a couple pieces of steel tubing with a bicycle rotor. The rear kit I have in mind is all atv parts that are modified and a custom bolt on caliper mount
well i found a rotor hub, that works with the stock axle, i located a source for a mechanical caliper for a foot brake , and now just need to find a rotor that works witht he hub as the one that works with the hub it 8 inches and a little bigger than i would liek on a 70, and also lookign up ideas for a front brake system also.
200x disc might fit, i know it fits the splines on a 90
84 ATC 70 w/88 (for the kids)
85 Yamaha YTM200 (Protek suspension / Tecate forks)
74 Joker frame ATC 90 w/ 110 cdi
71 Honda Z50AK1 Mini Trail w/117cc stroker
CRF50 stunter w/117cc stroker
08 Yamaha WR250X
My feedback:
http://www.3wheelerworld.com/showthr...89#post1080789
Your the only one who wants to see it lol. sorry I already have someone in mind to test it...me haha. The one in this picture is a bolt on but I had to drill two holes in the frame, The design I have in mind will be completly bolt on no drilling,welding,ect. There just doesnt seem to be enough interest to justify my time and money to put several together right now. I may put a kit together and throw it up on ebay to see what kind of interest there is out there.![]()
are you using a hand brake? i have been hording a working caliper, line, and master from a chinese quad but it will be hand operated. not a big deal to me but might be to some. how is your caliper mounted? caliper mount to frame? i cant tell from the pics. have you talked to jsmay? he's putting a couple 70's together and may be interested also.
since you'll be testing this one can we expect to see you with this at the next race? maybe a 70 showdown?lol
