Originally Posted by
donwon
nephew is dying to ride this alpha sport lg90 someone gave to him, just need a manual to fix carb. leaking fuel out of carb and won't idle. we got to get this kid riding now, he don't know about 2 stroke yet. any help is appreciated. thanks guys.
You shouldn't need a manual..
Remove the carb, give it a good cleaning..especially the float valve since that would be why the gas is pouring out. Put it back to together and try to find a rough set to get it running, then dial in the setting screw until it idles well.
While you are at it drain and refill your tank with fresh gas..no point in going thru the work to clean the carb if you don't know how long the fuel has been in the tank and if it's bad.
Once you've done one you could pretty much tear down any carb 2 or 4 stroke since they are mostly the same fundamental design.
Current toys..
1986 Honda 350X..trail bomb!
Current non-trike toys:
1990 Honda TRX300FW
1995 Seadoo GTX
1998 Polaris Touring 500
1998 Club Car (electric)
