Thread: 85 honda 70 wiring
    remsandpets's Avatar
    remsandpets is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2012
    Southwest, PA
    368
    85 honda 70 wiring
    I have looked over the schematics but can't figure out where the plug coming out of the stator area of the motor goes to. Coil has only one wire to it besides the ground and that comes from the kill switch. My question is, where does this pig-tail go and where does the coil get power from? I'm missing somethin?
    Russ J in SW PA
    83 Honda 200 (fishing and hunting "rig")
    83 Honda 185 (parts)
    95 Polaris Xplorer 300 4x4 (WIP)
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,248
    the plug goes nowhere, the black wire out of the stator hooks to the coil and the black on the kill switch.. and thats it...
    Beaver Falls, PA
    2,666
    There is an extra wire to run lights if you choose to...
    Feb 2012
    Southwest, PA
    368
    I did not see just a single black out of the stator. I will look again. My issue is that it looks as if the steering was turned while the kill swich wires were bound and pulled them off the coil. I did not see any other wire to the coil. Just the 2 from the kill switch. But I will have to take a second look. All the gas has been drained and carb cleaned. There wasn't but a little dust in the bowl and little surface rust here and there, not too bad. Its not a museum trike.
    Russ J in SW PA
    Feb 2012
    Southwest, PA
    368
    Found the black single wire. Female plug that could go to the pigtail with the other wires, correct? There still was no wire to the coil from that wire. I can see the ground wire was pulled apart but there was no wire from the coil to anything. Just a stripped black wire from the kill switch along with the ground wire. SO the single wire from the stator goes to the coil and the kill swich black wire? Thanks for the help.
    Russ J in SW PA
