Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 73
Thread: atc 250r Questions
  1. #31
    Mar 2012
    New York
    135
    yeah my guess also
  2. #32
    lazybiker79's Avatar
    lazybiker79 is offline At The Back Of The Pack Arm chair racerFirst time rider
    lakeland FL
    156
    you may parts inside it going bad.. open it up and check it out.
    3wheelers I own now: 86-ATC500R 86-KXT500 87-KXT250
    Check out my 3wheeler videos on youTube Lazybiker79
    http://www.youtube.com/watch?v=UNy9k...qljTifaAX47-6w
  3. #33
    Blossvale NY
    4,563
    But it's not a huge difference, and if you ride in any kind of wet conditions at all it's not worth the trouble. Engines don't like their fuel/air mix with a shot of water.... Great for dunes and dry condtitions though!
    What I have done is kind of a blend of both approaches.... I removed the snorkel pipe that connects the airbox to the main frame backbone. While it does pose a little more risk of water ingestion, it does open up the airflow alot while providing most of the protection of running the full airbox. Had to jet up 2 sizes when I removed that snorkel pipe.
    That might be a better alternative for you if you want better airflow without running a full airbox eliminator setup.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
  4. #34
    Mar 2012
    New York
    135
    really? i didnt know that i thought the engine just breathes beter...but it would efect jetting right
  5. #35
    Mar 2012
    New York
    135
    i oiled it and it was better but still a little hard
  6. #36
    lakeland FL
    156
    I was a world of difference on mine just taking the air box lid off..
  7. #37
    lakeland FL
    156
    Quote Originally Posted by william16339 View Post
    check your plug after and go from there.
  8. #38
    lakeland FL
    156
    Did you lube the cable?
  9. #39
    Mar 2012
    New York
    135
    plug chops
  10. #40
    lakeland FL
    156
    plug chops
    The color of the plug.. it will show the way you need to go with jetting.
  11. #41
    lakeland FL
    156
    NO check youtube..
  12. #42
    Mar 2012
    New York
    135
    yes i did cable is fine
  13. #43
    Blossvale NY
    4,563
    Really not hard at all if you are mechanically able.
    We are glad to help here at 3WW, but some topics have been covered quite thoroughly and a little time searching certain topics (like fork rebuilding) should net you plenty of results. Give it a try and check back.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
  14. #44
    Mar 2012
    New York
    135
    yes ride it wo then check it
  15. #45
    Mar 2012
    New York
    135
    no? what does that mean
