Thread: How do you remove a '86 Tri-Z's alternator from the engine?
    Jun 2012
    Southport, United Kingdom
    26
    Question How do you remove a '86 Tri-Z's alternator from the engine?
    As the title says, how is it removed? By looking at diagrams it looks like it should just slide ofg, am I missing something here? Once it's off i can remove broken bearings, replace them and get my Tri-Z running again. Thanks for any help!
    YTZ250S - In pieces, soon to be running!
    you have to split the cases to replace the bearings... and you need to buy a fly wheel puller .. thats the only way.
    Jun 2012
    26
    Thanks for that, I have already tried using a bolt puller kit which does the same job but the thing just wouldn't budge, it's been sitting for over a week and still nothing even with WD40. As for splitting the case I already knew that but thanks for saying as I may not have known about it.
    Mexico
    9,018
    You need one of these and you need to know how to load it up with force and rap it with a straight on to free the part. Don't risk your parts with other styles of pullers.
    http://www.ebay.com/itm/YAMAHA-YTZ-2...b0cb23&vxp=mtr
    OHIO
    2,857
    Buy the correct puller for the application for under 20.00. With a rubber mallet and under pressure from the right puller...a few whacks and it should come off. http://www.ebay.com/itm/Motion-Pro-F...e17d38&vxp=mtr Good luck..
    Jun 2012
    26
    Thanks guys, I will remove the bolt puller and purchase one of these for it.
