Results 1 to 11 of 11
Thread: Questions about the coil on my Honda 110
    Jan 2005
    Columbus, Georgia-Mid Dixie
    5,301
    It appears that the coil on my 110 is bad. I am not getting any spark from it. The previous owner used and piece of an Accel 8MM plug wire for it but that repair did not do any good. Are there any other parts I should check before I buy a new one? Also, I did some checking and they appear to be hard to find. Even sites that have them listed do not have them in stock when I call. Is there a coil off of something else that will do the job?
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    83 YTM 200L For sale,
    82 Tri-Zinger 60 For sale,
    8? YTZ 80 Conversion,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Baltimore, MD
    6,088
    I know the 84 and 85 honda 110 are the same. I know 83 is cdi and you may want to check a parts microfiche to see if they would swap. Did you get rear mudflaps yet? I may have a pair for you.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Jan 2005
    5,301
    I figured it fit something else. I made some mud flaps that look pretty good. Are there any other parts I should check before I try to replace it?
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Dahlonega,GA. (Formerly Flint,MI.)
    787
    Those coils are all over E-Bay...reputable sellers too. Aftermarket new. Before you do anything...try removing the plug cap and clipping off 1/4"-3/8" of the plug wire. They get old and corroded over time and a fresh clip will expose new wire. Definitely a new plug too.
    "You should never smoke in pajamas..
    You might start a fire and burn your face..
    Maybe you should return to Manaugua..
    You could go un-noticed in such a place"
    FZ
    Ass,gas or grass....nobody rides for free!
    Ride free,Brotha. See you in Heaven.
    Jan 2005
    5,301
    What about the switch? How do I check that?
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Baltimore, MD
    6,088
    I'd make sure and go through your wiring system and at least check for continuity if not resistance too. Your shop manual should tell you how to do it. Anything that does not have continuity is bad and the resistance tolerances should be clearly listed. Best of luck. Gazoos' 350x drove us crazy as we had continuity and the resistances all were in spec but it still didn't show any spark. We put the plug in and the trike fired up! Go figure? LOL We still never ever saw a spark at the plug????????
    Nicholson 185s
    Jan 2005
    5,301
    Hmmmm, I wonder if I that is the problem. I am assuming it is not sparking becuase I do nto see it. Plus, I used a test light and sprark tester on the coil with no luck.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Mexico
    9,018
    Quote Originally Posted by LonesomeTriZ View Post
    There is a way to test that out with your hand if you don't mind being "shocked" by the results
    Jan 2005
    5,301
    I like the way it tingles.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Mexico
    9,018
    You're a better man than me. I about soil myself everytime I get a shock. Best of luck getting this fixed.
    Jan 2005
    5,301
    It looks like I need a voltmeter.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
