Results 1 to 3 of 3
Thread: 81' ATC 110 Shift Drum Stopper Bolt
    Jul 2012
    Marysville, OH
    5
    Hey, I'm still new here and having trouble navigating this sight. Can anyone please point me into the correct direction of how to change a shift drum stopper? From my research, it seems very common for that little bolt to break and my manual isn't very clear on how to replace it. It will spin the indicator like it's going into gear, but doesn't actually shift into gear...Any more help would be greatly appreciated!!
    6,798
    You shouldnt need to replace the bolt just the drum stopper . Drain the oil and put a egg crate under the right rear tire so its leaned over and remove the clutch cover . The drum stopper is behind the large gear , you cant miss it . You will have to remove the clutch and the large gear to replace it . The clutch nut will require a special 4 prong socket or if your good with a punch it can be removed that way . Get a manual for the small details but its not hard at all .
    Jul 2012
    Marysville, OH
    5
    Sweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeet. Thank you sir.
