Results 1 to 3 of 3
Thread: 86 350x bog
    Sep 2012
    cromwell
    4
    86 350x bog
    I just reassembled my 86 350x, put gas in it started it up and went for a ride.
    i found a mid bog in the throttle, so i removed the air box lid,
    and now it's better, but the bog is higher up in the rpm range.
    i also discovered it's a mikuni carb. not a kehlin carb,
    could it be the the main jet is to large ??. or is the carb to large ??.
    it also did this before i diassembled it to restore it. i never thought to check and see
    if it was the stock carb. now i know why the stock throttle cable didn't fit correctly.
    Any idea's???
    Jul 2012
    Douglas, Ma.
    124
    How high in the PRM range? Is it right where the main jet takes over?
    fingerlakesny
    2,834
    i bought a 350x with a 400 ex carb on it. it ran great and had more power than the stock carb... ... so that goes to show ya how close some of the carbs are.. good luck
