Results 1 to 15 of 15
Thread: Project X
    DIGGER DOG is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    in the sticks s.w ga
    446
    Project X
    Well It has begun this will probably take years to complete as I dont have any $$$$$
    1st step Im going to make is getting a kick starter and spindle,This thing does run :shock: I want to get it running so I can find all the leaks so I can order gaskets and or rebuild motor it has been rebuilt once by a 15 year old (no disrespect to our younger members)but this guy did it back asswards I remember him mentioning studs breaking during the process.
    Monday I check on a rolling chassis.
    frame has just about every bolt hole stripped.
    needs all motor mounts+nuts+bolts.
    needs exhaust,seat pan+seat,rear mst cyl,front mst cyl,front caliper.
    all brake lines+resivoirs...etc...etc...etc...
    I know the front wheel in on backwards :-D too
    83 YTM 200,84 200X,,85 350X basket case,86 350X parts trike,86 350Xroller needs top end, 86 250SX,
    446
    Parts I need list with the exeption of internal motor componants
    all motor mounts ,spacers and bolts and nuts
    front and rear brake lines ,front caliper,master cylender,front and rear brake resivoirs.
    right foot peg+bolts,rear and front brake levers.
    kick starter +spindle(internal) :-D
    gas tank,seat pan foam and cover.
    all plastics,handle bars,rubber mounting grommets.
    front hub rear axle bearings.
    fork rebuild kit.
    preferrably another frame.
    full exhaust sys.
    new brake and clutch cables.
    rear brake light,seat latch and grab bar.
    carbureater rebuild kit.
    on off /head light hi low switch,possibly complete wiring harness.
    all I can think of now Im sure the list goes on and on
    Apr 2002
    s.w. michigan
    6,498
    x project
    wow digger,, you sure got a list of needs ! i just started a 'R" project and thank god i don't have a needs list like yours.
    but to think about it,,, last year when i was doing my 2nd. 350x i ended up with almost all the parts you listed on my needed list,,, lol.
    good luck,,, have fun + be careful....
    john
    Eastern Long Island
    1,688
    Not only is the front tire on backwards but the forks are backwards too. It should be a leading axle. I have an 85 frame that I can check out and the internal kickstarter parts you need. I will be going through my parts tomorrow to sort out the junk and put the rest on Ebay. If you are interested pm me and I will tell you all that I have and give you a great package deal. :-D
    Todd
    Lots O Trikes!!!!!
    Apr 2003
    Bay Area CA.
    2,638
    is that an fmf silencer on it??
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    446
    absolutely correct it is a leading edge set up and the forks are on backwards :-D definately interested in the parts ya got sent a pm.
    yea that is an fmf silencer that was frankenstiened on there
    Mine were big turd too when I started them. I'll go thru my stuff tommorow too. I know I have a engine skidplate MR ATC sent me 5 of them. and I have footpegs and maybe the levers. I also may have the oem bars too. The engine mounts are the toughest to find. the 2 spacers on the front you can get from service honda still. like I said I'll go through my stuff and see what I got. have fun!!
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    446
    whoaa :shock: blazer service honda doesent have motor mounts aww crap Im gonna have problems then I actually have a motor skid hopefully this roller im checkin on will have some mounts hopefully but doubtful I dont hink it has a motor.
    Yeah they don't have the mounts only thing they have that I got from them are the spacers for the front mount.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Bartlett TN
    3,083
    There are some motor mounts on ebay.
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=43972&item=2445692 427
    86-87 Tecate ROCK!
    446
    killer fellas thanks its gonna take a good while before this thing gets finished I doubt Ill be riding it this summer
    446
    whoooo hoooo we have motor mounts but one is broke one of the front uppers broke right in half but hey spares would be nice too im gonna try and get every little bit i can ,the frame is shot its rusted half ways through
    on the left side just above where the left foot peg bolts up where the bracket is welded to strenghen frame
    446
    200xman this is no big deal and I dont mean to correct you but the forks on my x project are totally wrong for the bike period look at the pics closely :-D they are NOT 350X forks at all they are 250R forks :shock:
    I wonder what else ill find on this thing
    446
    Big trouble the rolling chassis I was going to buy may be sold to a friend of one of the guys that work at the local cycle shop that i was going to get it at this guy has a kx 250 motor he wants to put in it
    Aaron2003's Avatar
    Aaron2003 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2003
    293
    motor mounts are the easiest part, they are really easy to make yourself all you need is a little bit of 1/4" flat metal stock and a template and there you go, any welding shop can make them for you cheap..... then you can paint them what ever color you wish... good luck
