Flossyb20 is correct that you should avoid running out of gas on a 2-stroke, especially at high RPM's. It causes the engine to run so lean that it "diesels", which means that the fuel mixture ignites itself on compression, which is why your kill switch doesn't shut it off. Definitely not good to run like that as there is precious little oil/fuel mixture to lube the cylinder.
As to the gearing I run my '83 stock (100% original bike) and find that is the best gearing combo. I have plenty of bottom end and top speed in 5th is plenty fast enough. I wouldn't personally run an 11T on front. On the project '82 250R that I am building I decided to go up 1 tooth on the front sprocket to a 14 and ran into the problem where there is not enough adjustment to make up for the 1/2 link that I added. 1 chain link = 2 teeth on a sprocket. I had to buy an offset link (AKA 1/2 link) which I don't like to do. Everything on this bike is new, including chain and sprockets, and now I have a 1/2 link that is much more likely to fail on me. If you really want more torque on your 84 I would recommend adding 2 teeth to the rear sprocket or adding 1 to the rear and going down 1 in the front (you should always replace chain and sprockets as a set).
Just my opinion, I could be wrong : )
1983 ATC 300R (Hondaline kit)
1985 ATC 310R (CT Racing)
1986 TRX 250R (Bone stock)
1988 TRX 330R (ESR)
