Thread: Is Gasket sealant necessary?
    Michigan
    1,144
    I am putting my 125m motor back together after having to split the case to fix a transmission problem. I have a new gasket set and am wondering if a gasket sealant is necessary? If so what is best to use?
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    Gripit'n'ripit's Avatar
    Gripit'n'ripit is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    Rochester NY
    251
    I do not believe it is necessary. Most of my manuals don't even mention or suggest it.
    81 250R Custom
    83 250R (in progress)
    98 Scrambler 400
    03 Bombardier Quest 500
    07 Polaris Predator (sold to klondike1020 )
    68 VW Dune Buggy
    Sarnia, Ontario, Canada
    3,415
    Not if you use good gaskets, unless it's a cover you might want to remove again like the clutch or CDI
    cover. For this application I like a thin layer of grease to keep the gasket from sticking.
    There are occasions I like to get gasket adhesive..spray it on the gasket and cover to stick the gasket so it doesn't slip out of position during assembly.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Slidell, LA
    4,738
    Gasket sealant is necessary where your manual tells you to use it. I recommend Hondabond HT.
    southern maine
    67
    or in areas where any pitting or galling it present ( somone prying cases apart with flat heads etc.)
    Give it a little flat file and maybe a dab of sealant if you still feel a nic.
