Thread: Atc 200 e exhaust help , please
    Aug 2012
    Galax , Virginia, USA
    I got my bike running well now, but the exhaust leaks like a sift right where the header and mufler come together. I may just need a clamp , but what i dont understand is how it works. The pipes are rigid and there is not slot for the pipe to calmp onto the muffler. The header slides right into it but i just dont get how the clamp can tighten two pieces of solid pipe? I guess what i want to know is do i have to get a oem clamp for it to work, what is the best way to fix this, i now i need to take it Aparts and wire brush it really good, but i just want to do this only one time, if ya know what i mean. any helps , tips , hints, anything you have will be greatly appreciated. I really like this forum and i have already met a few good friends.
    Thanks
    May 2008
    Pomeroy,PA
    86
    Sounds to me like your missing the gasket that goes into the muffler end. The head pipe then slides into the gasket and a clamp holds them tight together. Its a sleeve like gasket. Cost about $10 from honda
    Jun 2009
    Tunkhannock,Pa
    904
    i imagine you could also use muffler tape
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    OHIO
    2,857
    You could use high temp silicone on the 2 also.
    Mar 2011
    Red Lion pa
    1,542
    Look your model up on just about any online parts store. Most will show you an exploded view of what ever section your trouble shooting. Heres a link to cheap cycle parts .com (not always the cheapest) showing you exhaust set up and you can also retrieve part #'s for reference if you want to just go to your local parts store or on Ebay. http://www.cheapcycleparts.com/model...s/2714-muffler You can also get manuals to down load off of this site for your model.
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 black (project)
    86 klt 185 red
    85 klt 160 (Floyd)
    85 klt 110 X2 (projects)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
