I picked up a Honda 1982 110 yesterday for $80. The motor wouldn't turn more than a full turn because the cam timing was way off, and after fixing that it had no compression. Figured a bent valve from the timing being off, but it was just a bunch crud under the exhaust valve. Clean and lapped the valves, then cleaned the carb and had it running.
Compression is low and it smokes so I'm going to put in some new rings. The airbox isn't hooked up, and it and the tank look like they're off a newer 110. It needs a pull start, cdi box (I stole the one from my 185 for now), and axel bearings front and rear. The seat is real rough, but there's not a crack in the fenders. Not to bad a deal I don't think.
Here's some pics:
Trikes Currently Owned:
