Results 1 to 15 of 15
Thread: ATC70 Air Cleaner to carb rubbers any interest??
    Howdy's Avatar
    Celina, Ohio
    10,079
    Having a few Atc70's I have found it hard to find good air cleaner to carb rubbers. I can't find a Honda Parts Number to see if they are available, but I do know the air cleaner assembly ( rubber boot is on the assembly so I assume it came with it ).
    Now I have made a few of these molded from one I had ( I can do custom colors ). I was just wondering if Honda sold them seperate and if so what is the part number.
    Thanks
    Howdy
    6,811
    As far as I know the only way to buy the rubber boots , you had to purchase the " air cleaner housing " here is the part#
    17221-957-000
    And yes long since discontinued .
    This is a very good part that needs to be repoped .
    Apr 2002
    s.w. michigan
    6,498
    Looks like he IS making them Mike.
    Nice work Howdy ! Addictive hobby isn't it
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by jeswinehart View Post
    Way too addicting. LOL
    Mike, I am currently re-doing the mold for the Air Cleaner to carb. the original Mold I made is OK, but not Ok enough for me. ( Swiney has the bar set VERY high ). I am also working on the Mold for rubbers on the back side. I never realized the back was 2 piece. I'm guessing the inner part is used as a restricter plate and easily removed.
    Howdy
    May 2011
    eden,ny
    3,481
    I have no need fo one since I am using a different engine intake ect. but I did notice when I got the trike that that piece was missing from the airbox but had a nice snorkel(for clean air off of the airbox.I am guessing that the reason the carb side doesn't survive is from fuel passing over it. On the same note I know some of the chinese quads use an identical airbox so that boot may be available already. but if I needed one I would call on you before china. nice work howdy.
    Nov 2004
    Waterloo IL
    2,701
    I would probably take a few, just black. I know dratv sells em for the CT70 but I don't know about the ATC70. Would be nice to get them for SL70 and XL70 too.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    6,811
    Sounds good Howdy !! I'm in for a few when you get them done , seems like every atc70 that comes threw the shop is missing the front boot .
    I have tried the china ones of similar style and the ct70 and their all the wrong angle .
    Quote Originally Posted by Howdy View Post
    Howdy
    Howdy's Avatar
    Celina, Ohio
    10,079
    Michigan
    1,144
    Between you and John we will soon have a source for alot of discontinued parts. Keep up the good work you two.
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    Van down by the river
    3,874
    Looks great, im in for a pair.
    R.I.P. John Swinehart
    Epic Mikfest 17
    86 200x
    85 250sx
    85 big red
    85 atc 70
    Aug 2004
    Phoenix
    1,229
    Another option is to purchase the boot from dratv.com
    http://www.dratv.com/bootcartoair.html
    It is listed for the CT70 but I have used it on 4 atc70's and it is identical.
    Remove all the warning label and let nature take its course
    6,811
    I've had both a ct70 and atc70 side by side and the boots are totally different angles . The one you say that fits from DRATV must be different than a normal ct? but thats great if it works .
    Quote Originally Posted by 3Razors View Post
    Howdy's Avatar
    Celina, Ohio
    10,079
    I gave a OEM atc70 boot to a friend to use on his CT70 last year and he said it didn't fit properly. hmmmmmm
    Howdy
    Aug 2004
    Phoenix
    1,229
    The DRATV boot is an aftermarket unit, the variance of fit might not be as exact as oem..maybe its made to fit a wide range of years of 70's but they all should be the same. It does fit the atc70 perfect if someone wants to use one, its been on my atc70's about 4 years now.
    6,811
    I believe it was a good 30 degrees off or so . I was in the same situation looking for a boot for my 1971 ct70 and the atc boot wasn't going to work .
    Howdy
