Thread: ATTN.all year 250R and 350X owners
    DIGGER DOG is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    in the sticks s.w ga
    446
    Ok fellas 1st question for the 250Rs front fork set up on all 250Rs are trailing axles right not leading axles?
    2nd question 350Xs all the 350Xs are leading front axles correct?
    3rd question can the 250R forks be turned around making it leading axle
    for use on a 350X ??
    the reason Im asking these stupid questions is because my 350X project has 250R forks hopefully this roller im going to see has the right forks or forks period .
    man the mess keeps getting bigger and bigger.
    83 YTM 200,84 200X,,85 350X basket case,86 350X parts trike,86 350Xroller needs top end, 86 250SX,
    250r's are trailing
    350X's are leading
    If you turn the 250r's around, your brake and rotor and everything else will be bassakwards.
    The thing to do is get a set of 350X forks and swap in the 250R innards. You get more travel and much more spring rages are available for the 250R.
    Not what you wanted to hear eh? Mr. ATC has posted bout this but I'm not sure where. Might try searching for it cause as I remember it, he explained it in a bit more detail.
    Happy Wheelin'
    SloPoke
    85' ATC350x
    8? ATC70
    446
    slopoke
    thanks man I didnt think i could spin the things around just wanted some confirmation.
    hey also i noticed you have a 1/4 turn throttle on your big X where can i get a set up like that I have a twist on my 200X and like the twist better than thumb does the set up come with a cable or would i have to frankenstein another bike throttle cable to make it work.
    thanks again man
    Jun 2003
    South of Rochester, NY
    3,470
    I was down to MR ATC's back in August. We (well more he) rebuilt my front 350X forks with new seals, boots, and Progressive Fork Springs. The diameters of the 250R and 350X forks are different, so you will need to change triple trees too. I remember Bill asking for a triple tree to clamp the fork into to get the cap off. I picked up a 250R one and he said it wouldn't work. Then proceeded to find a 350X one. :oops:
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Minnesota
    784
    You guys are both right, 250r's have bigger diamter forks, but you can put the innards in a 350x, you just need to know what year forks to get them from, I think the '83/4 innards will fit in a 350x fork, but the liquid R's have bigger forks therefor you'd need the R clamps too. I havn't done any of these mods, just going by what MR ATC has said. I can't belive the '83/4 R's would have a inch more travel since they were a year older than the 350x.
    446
    yea the big X i have has a complete 250R front end forks and trees the big problem I now face is the roller I was going to get is going to be canabalized by a friend of the guy that works at the cycle shop that i was going to get it from :evil:
