Page 8 of 9 FirstFirst ... 6 7 8 9 LastLast
Results 106 to 120 of 124
Thread: Project Childhood Fun Almost finished just need Decals!
  1. #106
    May 2013
    Brownsville, Tn.
    1,271
    Quote Originally Posted by 90guy View Post
    As for the boots they fit lossely on it. Wish they fit tight but what can you do haha!
    I used to use Zip Ties around the smaller end of the boot to hold them in place.
    * Nicholson 500 Race Bike *
  2. #107
    North Dakota
    1,643
    Well Been dinking around with it. Now I have a problem where I hold it wide open it will rev to a point and cut out kind of like a rev limiter. I tried to run the choke when it was doing this and no change. What could cause this? Running to rich? This thing start perfect. pull the choke 1 pull and running till I shut it off. Thanks
  3. #108
    6,811
    Try a new spark plug and adjust the points and if that doesn't work lean the jetting a little and see if that clears it up . A weak spark will act like a rich condition ......
  4. #109
    North Dakota
    1,643
    Thanks Mike, I was curious on that. Wasnt sure if spark would cause a condition like this. I will pick up a new pug tomorrow and try it again. Fingers are crossed as it just started doing this.
  5. #110
    Oct 2013
    Wherever I May Roam
    3,757
    As far as jetting goes,,,Cutting like a rev limiter at WFO ==...Lean main!! Or it is the spark as shortline said already...
    The pilot is likely fine if it starts one pull.
  6. #111
    North Dakota
    1,643
    Im going to try the plug and points. I was curious. Wouldnt opening the choke circuit up richen it up?
  7. #112
    Aug 2007
    Montana
    857
    Dang Your Project looks so good!!!! Thanks for the ride little chilly but fun!!! Talk to ya soon Ol Deuce
    DO the Best With What you got !
    My Feed back :cool
  8. #113
    North Dakota
    1,643
    Still playing around with the carb. Still a little boggy on the bottom. But its not cutting out like it did anymore. Here is a little video of how it sits now.
  9. #114
    May 2013
    Brownsville, Tn.
    1,271
    Man all you need now is some Old School Pin Stripe and that thing will be Bitchin'
  10. #115
    Aug 2007
    Montana
    857
    Some of the "Old School" pin stripes were UGLY like this one LoL.........
    My Feed back :cool
  11. #116
    6,811
    I would play around with the points timing , advance or retard it a little either way and see if that helps . Also are you using a short intake manifold ?
  12. #117
    North Dakota
    1,643
    OK I'll adjust that a little. Yup still with the shorty. I remember you sating had problems with a shorty on yours.
  13. #118
    6,811
    Yes the bottom end hick ups are easier to tune with a long manifold .
  14. #119
    San Marcos Ca.
    714
    Nice looking trike Todd, Time to start another one.
  15. #120
    North Dakota
    1,643
    Haha! Starting to collect parts for another one haha. Just need to finish up this 300r I have!
