Results 1 to 2 of 2
Thread: "1985 honda atc110"-$250
    St. Agatha, ON, Canada
    1,497
    http://kitchener.kijiji.ca/c-cars-ve...AdIdZ415624050
    1985 HONDA ATC 110. Probably be best used for part but could be rebuilt. It won't always stay in gear. All 4 gears work, but it sometimes "pops" out. Rear axle has bend in it so it shakes at higher speeds. Hi/Low works no problem. Tires are good but two have small leaks at the rim. Bike starts and runs pretty good. Chain is off at the moment. Inside of gas tank is rust free. Please E-mail me for more details. Bike is located in Stratford.
    Thoughts? What would likely be the cause of it poping out of gear? ho easy would it be to fix or replace the rear axle? what other axles would work?
    1983 Honda ATC 200e: my first true Man Toy!-Sold for $200 on Victoria Day
    Ice & Trikes 4 Life!
    If Nissan Motorsports = Nismo, does Honda Motorsports = Homo ?
    fingerlakesny
    2,834
    sounds like they took the chain off so you cant test ride it... buyer beware.... probley a transmission problem.. the axle isnt that bad of a job but by the time i bought the atc, and axle , and figured out the transmission.. in my area im way ahead buying a runner..... good luck on whatever you decide....
    250r dust runner
