Results 1 to 8 of 8
Thread: will a 90 motor be a straight swap to 110 frame?
    Mar 2011
    Red Lion pa
    1,542
    I pulled the motor out of my 90 to use as my "school project" for the small gas engine repair classes I'm taking. This is when I found out the frame was split about 3-4 inches in front of the motor mount holes. I have what I believe is an 82' 110 frame with a locked up motor. Will the 90 motor swap right in?
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 black (project)
    86 klt 185 red
    85 klt 160 (Floyd)
    85 klt 110 X2 (projects)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
    fingerlakesny
    2,834
    i believe it would, use a tape and measure the bolt holes for mounting....
    250r dust runner
    Mar 2011
    Red Lion pa
    1,542
    Will the rear sprocket align correctly if the motor mounts.
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 red
    85 klt 160 (Floyd)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
    Beaver Falls, PA
    2,666
    should be a straight swap, but you'll have to use all the 90 electrics(90=6v system)
    Howdy's Avatar
    Celina, Ohio
    10,079
    If you would prefer a Stock 90 frame then let me know the year of yours. I should have one available cheap + actual shipping.
    Howdy
    Mar 2011
    Red Lion pa
    1,542
    Thanks guys...and howdy i let ya know. Not sure where i want to go with this one yet. Will all depend what is found inside when it gets opened up. Probably just try to make it a runner. Being a "virgin" to splitting a case, who knows what I might screw up. I plan on taking lots of pics of the motor tear down/rebuild (more for my own benefit of getting back together) so if I find something I'm unsure of I'll be sure to hit you guys up. Thanks again for the replies!
    Mike
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 red
    85 klt 160 (Floyd)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
    bandito90's Avatar
    bandito90 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Pa
    284
    Mike, There is also a 90 frame at Bruce's you can have and I have a few 90 motors tore down if you might need a few parts.
    1978 bandito framed atc90
    1984 YT60
    1974 rd60
    2002 Buell Blast
    1984 Honda xr100 project in the trunk of my car.
    1964 honda C100
    1981 Honda Hobbit
    1984 Yamahopper
    Mar 2011
    Red Lion pa
    1,542
    Thanks Tim I appreciate it! I'll more than likely be in contact
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 red
    85 klt 160 (Floyd)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
