MY FRIEND HAS A HONDA 700 NIGHTHAWK 1985. 4 carbs. that need a good cleaning as when i ride it it is very sluggish, and hesitates.. can i take the carbs off the bike and if it has two nuts on the throttle cables leave the top nuts in the original place so i would put it back together were the factoty had it and pull the float bowls off all 4 carbs , clean and put back together and have it run great ? im not familiar with the tubes i heard honda uses...it just seems like if i have the throttles back at the correct position and just clean the carbs and put the jets back the same # of turns it will work fine ????
