Full Disclosure: This is for a four wheeler, but I told my nephew I'd try to get him an answer ASAP. Please forgive me for my transgressions of posting a quad question in Trikesylvania, but I wanted the traffic here to get an answer. Thank You!
The reason I'm asking here is because while I have worked on these machines before, I've never been in this situation.
Here's the scoop: My nephew and a buddy are working on a 01 Sportsman 500 and had to replace the head gasket. In their hurry to get this job done, they had the front cam chain guide improperly installed. The head had to be removed to properly place the cam chain guide and he is wondering if they can re-use the head gasket.
The particulars:
The head gasket is a multi-layer steel gasket
The motor was never run so it never got hot.
The torqueing process for this particular gasket is unique to say the least:
tighten to 22 ft lbs
tighten to 51 ft lbs
loosen 1/2 turn
loosen 1/2 turn (by this time the head is basically loose again :P)
torque to 11 ft lbs
tighten 1/4 turn
tighten 1/4 turn
I actually add another step here and make sure they are torqued evenly, which is 45 ft lbs
Soooo, since the head is basically loose before you retorque it again, I'm thinking it may not be a big deal to re-use the gasket (and add maybe 5 ft lbs more of torque) since the gasket has never been "set" by being heated to operating temp.
