Results 1 to 15 of 17
Thread: Tri-Z and In-line Radiator Coolers: Do they work?
    Arizona
    843
    I've got an overheating problem on my Tri-Z and I'm entertaining solutions. Ever since I ported the cylinder (including an additional boost port) and upped the compression, heat fade has become a problem. It runs like a Banshee for about 5 minutes but then the heat builds up and the power fades. I've got a Sprock cool head and a high flow impeller but it is still a problem. It is not a lean jetting problem; I've dialed that in.
    I'm probably going to do a number of things to solve it. One, scrap my DG pipe as I think it is too restrictive and get a Jemco. Two, I'm thinking about trying some inline coolers, the 5 inch ones, not the short Pro-Design ones. Has anyone tried these and did they work? Pro-Design claims a drop of 5 to 10 degrees but that is a pretty big claim, especially for a 2 inch cooler.
    Yamaha should have used wider radiator shrouds on the Z. They are tucked-in behind the front fender so they don't funnel air through the radiators. Wider shrouds would have looked cooler, too.
    I would also consider larger aftermarket radiators but I've searched the internet and haven't found any.
    May 2012
    From what i have gathered here at 3ww is there are 2 problems with the tri-z cooling system. 1. Water pump impeller 2. Thermostat. You have fixed one but have you dealt with the thermostat?
    OHIO
    2,857
    Neither of my z's have the thermostat in them. Recommended from the 1-800-Tri-z hotline....aka Raffa....lol Give Bryan a shout or he may chime in on your problem. That fella knows those things inside and out!!
    Aug 2004
    Ab Canada
    4,368
    I run the t stat eliminator, only time i have issues is when the rads pack with mud..also straighten the fins out often, my rads are pretty beat up and bent but still cool fine, im also running high compression on 110 leaded fuel.
    1985 Tri-Z-
    N.E. Ohio
    2,005
    Waterless coolant...sometimes helps keep the temp more consistant and less likely to over heat. You are running Race fuel correct? Condition of the scale build up inside the radiators and thermostat could be an issue and causing the stat to malfunction or not work at all. I've never run into much in the way of over heating. You rad cap is good...seals correct, good flow inside? I am running an eliminator on the race motor with an in-line cooler. That bike isn't going to see much in the way of idle time like a trail machine, with the overflow bottle being pretty handy.
    Tucson
    1,652
    Chris Im using the Eliminator also!Click image for larger version.
    Arizona
    843
    So, eliminate the thermostat and it will run cooler? Is the theory behind this that the thermostat is too restrictive, it slows the coolant down, and allows heat to build up?
    zzmegad's Avatar
    zzmegad is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2008
    North of Chicago
    317
    Quote Originally Posted by christph View Post
    well at least then there is no question of the flow through there... plus it looks like his has some cooling fins on it, I guess every little bit helps if you think you are pushing the limits of the Z cooling system. I personally run my t-stat and have never had a problem, I tested it and it was fine so I kept it.
    louisiana
    1,499
    Run some engine ice in it.
    http://www.engineice.com/
    Signature pic removed,becuase of no helmet.
    May 2012
    For coolant I use evans powersport coolant. Great stuff......... http://www.evanscooling.com/products...ports-coolant/
    Tucson
    1,652
    Just something else to fail,,, honesty if it really needed it all the 250R's and other 2 strokes would be using them! So again its just another part to go bad and not having it is one less thing to worry about!!
    pcs's Avatar
    pcs is offline Just Too Addicted Arm chair racerJust too addicted
    Jan 2011
    yuma, az
    465
    chris, unless you live in flagstaff i wouldnt worry about need a thermostat, people that live in cooler states dont have problems with thermostats bc cooler ambient temps allow them too, here in hot azz AZ we need all the cooling we can get. i dont feel like getting into a thermodynamic, heat transfer, and coolant flow discussion so check out this link. simplifies everything real eazy. increasing coolant flow with help increase cooling to the engine, to a certain point.
    http://www.arrowheadradiator.com/14_...utomobiles.htm
    Team Blue: 85 Tri-z 250: under the knife
    Team Red: 87 Trx250r 01Cr80 15 CBR600RR
    Team Yellow: 06 Ltr450 11 Hayabusa
    Ya take the termo OUT!!! and put it back together... and yes a cooler works anything to draw the heat away and create more surface area for cooling!..it worked great for when it was cold out... but 25+ years later they stick and you over heat...not good out on the trail!
    Also you got a maire? Or stock front fender? The maire restricts the airflow more into the rad's as the slots are not cut as big.
    GMX in Australia made a few sets of over sized rad's.. it took me all day to think of it.... no wait it was the UK!!! http://www.gmxradiators.co.uk/
    Attached Thumbnails Attached Thumbnails 24554_372664650964_1262152_n.jpg   24554_372664675964_1454328_n.jpg
