Results 1 to 15 of 19
Thread: 200x top end no oil .......
    PAPA250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    greentown PA
    389
    I think my 200x is not getting oil to the top end .... I took the back right head bolt off and both rocker caps . I see no oil ? Should oil flow out of the back head bolt when its removed ?? Whats the best way to chek for oil flow ? I have a 200s valve cover on it so i dont have that bolt with the. Copper washer on it
    Bad oil pump or clogged passages ? What should i check. Thanks
    84 200s almost done
    84 atc 70 project
    6,812
    Remove one of the valve covers and start it up . Should be plenty of oil visible their . Can also shine a flashlight and see if the cam valley has oil in it .
    Feb 2009
    greentown PA
    389
    There was no oil found the culprit . took the right cover off there was Rtv stuck in the hole leading up to the top end . Soon as i get a new gasket which i broke should be good . At least i didn't fry the top end . Still ran good lol
    84 200s almost done
    84 atc 70 project
    6,812
    You got lucky !
    Slidell, LA
    4,738
    I second that!
    Feb 2009
    greentown PA
    389
    I see 2 passages there .... One going up to the right rear head stud was clogged ... What does the other one supply ?
    84 200s almost done
    84 atc 70 project
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by PAPA250r View Post
    The one should flow throught the right side case and go to the crank shaft.
    Howdy
    200xranger's Avatar
    200xranger is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2007
    St. Louis
    207
    i had the same hole get clogged with rtv and wasnt so lucky!!! cam seized to the cam bushing and locked everything up which also stretched the timing chain beyond belief!!! lucky you!
    Three Wheels Are Better Than Four!!
    My Rides:
    85 250r atc
    85 tri z
    2012 honda rincon 680
    Feb 2009
    greentown PA
    389
    Dam lol. Got lucky for a change lol
    84 200s almost done
    84 atc 70 project
    Scootertrash's Avatar
    In the sticks
    4,638
    PAPA and 200xranger--What was the RTV used for?
    Feb 2009
    greentown PA
    389
    Guessing the valve cover . Only rtv on my engine
    84 200s almost done
    84 atc 70 project
    Feb 2009
    greentown PA
    389
    Ok ... It was flowing fine but now stopped again :-(. This time no blockage that is visible . Any ideas :-(
    84 200s almost done
    84 atc 70 project
    6,812
    You still have crud in the passages , also its time to inspect the oil pump very close for wear .
    In the sticks
    4,638
    What shortline said.
    Also, don't use RTV for your valve cover sealer. Use Hondabond (I think that's what it's called) or threebond 1194. IIRC that's what the manual calls for.
    RTV will kill ya, 3 Bond in certain places or a tiny amount for silicone if cases have a ding in them etc etc.
    You did put the teenie tiny rubber plug in correct? Thats how oil passages were made; Honda drilled then plugged the other side...........
    Then oil went to the proper place. Post up some pics if you can.
