Thread: 1985 HONDA ATC 350x Carb rebuild kits questions!!! read it, thanks.
    New york
    583
    Hello everyones here, i have a questions about rebuild the carb kits. I still have original carb and it leaking gas badly from bottom drain tube. Which ones i best go with a complete aftermarket carb rebuild kits? That goes for $20 and under on ebay or should i go with honda oem factory carb kit from my local honda dealership??
    By the way, my bike is all original and still on original stock muffler. Thanks.
    Sep 2007
    100mi west of Chicago
    3,582
    I would try messing with the float in your current carb first, and you might just be missing the tiny o-ring that goes on the drain screw
    Rob
    fingerlakesny
    2,834
    yep , always a good idea to pull it apart and see how everything looks....good luck
    250r dust runner
    Clean it spotless, like 2 cans of carb clnr through every passage.
    Once I'm POSITIVE! I have everything out, I blast air and more carb cleaner through it.
    If you don't follow that last step, you find springs, washers and o-rings flying through the air and you will NOT ever find them!!
    Tucson
    1,652
    I will say if you can get oem get it!
    New york
    583
    Ok, i will try and do it. see how it goes.
    also i just bought a complete aftermarket rebuild carb kits yesterday on ebay for $20 bucks.
    Tucson
    1,652
