Thread: Sprockets and chain
    fingerlakesny
    2,834
    Sprockets and chain
    YEARS AGO I WENT up 3 teeth on my front sprocket of my dearly departed 350x honda. but had to leave the chain loose because if it had proper slack it wouldnt mesh properly with the rear and come off.... so what im triing to figure out is if i went 4 teeth bigger on the front would it work ? in general is there a rule of thumb about sprocket sizing ? its cheaper to buy just the front and not mess with the rear so im triing to figere this out..
    250r dust runner
    Nov 2010
    Oshawa, On, Canada
    2,123
    A 16 tooth sprocket would definitely not fit in there? I heard the max was 15 tooth.... so I don't know how you would get a 17 in there.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Abrams, Wisconsin
    739
    i don't understand how sprocket size would cause this to happen. maybe you had sprocket alignment issues?
    86 250sx - old reliable
    another 82 110
    -gone but not forgotten-
    82? 110 - why did i sell it??
    84 225dx - meh, it was a pile
    Williamstown PA
    5,825
    1 up/down in front is = to 3 up/down in rear. I'd rather change the rear out. dial it in with junk sprocket and chain, once you do buy all new stuff.
    The 15 for the front is the max and I believe it is a tight fit and the case saver cannot be used
    The 14 tooth front can use the OEM guard and sometimes needs a just hair of grinding. Those are the ones I leave the case saver bolts loose with with the chain on the sprocket. Then I can place it over the counter shaft as an assembly
    42/12 = 3.50
    44/13 = 3.38
    50/15 = 3.33 (If 50 fits above the skid plate)
    They're all fairly close.
    I wouldn't run anything without a case saver though.........
    I think stock is 40/13 or 3.07. It pulls a 14 front well with merely removing the air box lid, adding a pipe and getting some larger jets in there.
    An UNI filter helps to
    fingerlakesny
    2,834
    ooppss my bad it was the rear... no the alignment was fine but the -3 SMALLER rear sprocket ( guess im getting allsimers) just didnt take to a properly adjusted chain...
    250r dust runner
