Thread: Home made leak down tester
    Sep 2012
    Indianapolis
    69
    Hey guys,
    Just thought I'd start my own post on how to build a leak down tester for under 15 bucks. Since I can't post on the main forum yet heres an example for any new members.
    I found all the supplies at menards in the plumbing section. Do not waste your time looking for the low range pressure gauge at lowes or home depot as they don't carry them at least in indianapolis.
ID:	154840 Click image for larger version.
ID:	154841 Click image for larger version.
    0-30 psi gauge (Watts Band) around ten bucks
    3/4 mpt thread galvanized pipe about a dollar
    3/4 fpt to 1" fpt 90 degree elbow galvanized adapter about 3 bucks ( The large end of this piece will need to have an outside diameter that fits inside your intake boot) 1" inside diameter gave me the correct outside diameter for my 84 250R with stock carb.
    Hope this helps.
    Sep 2012
    Indianapolis
    69
    By the way the pressure gauge already has a valve stem to air it up.
    Apr 2012
    Northeast Nebraska
    7
    What does this test?
    Sep 2012
    Indianapolis
    69
    This is for testing for engine leaks from the intake to the exhaust port. In a two stroke a compression test will only test above the piston leting you know if your rings and head gasket is sealing. A leakdown test will test the crankcase and intake boot. If someone can give detail On performing the test that would help im on my iphone and it takes forever to type. If not ill do it later from home. You will need a freeze plug that fits the exhaust port as well.
    Apr 2002
    s.w. michigan
    6,498
    Here is some pretty good detail Mack.
    http://www.3wheelerworld.com/showthr...r-for-about-20
    john
