Originally Posted by
RIDE-RED 250r
Thank you very much El Camexican!
That is EXACTLY the issue we are struggling with. I think we will try that "T" fitting solution..
I had a thought that maybe it was due to being fuel pump supplied vs gravity fed, but I did not know they made carbs with smaller metering valve inlets for service on fuel pump supplied systems.
Although it's no PWK, I think this 34mm PE should be a descent upgrade for him. So far as we can determine at this point, it is only running an aftermarket silencer. Haven't disassembled the engine yet so we don't know if any other mods are present. We'll be doing a complete tear-down for inspection over the coming weeks....
Oh, one other question...The 2 petcock setup, what purpose do they serve? Which does what? We did at one point try halfway closing the forward petcock and it seemed to alleviate the problem for the most part... Maybe just coinicidence???
