if you go with the esr kit, IMO if you are going for high hp #s i wouldnt spend the extra money on their port job and just get a drag port from a shop that builds drag engines. like pantera said, getting them ported really works.for reeds, i wouldnt even consider anything from boyesen, they dont compare to vf 3 or the esr billet reeds for building high hp. if you go with esr reeds get the ones without the built in spacer bc it will give you more clearance with the rear shock and carb. carb 39mm or bigger with a UPP manifold. you can also play with the esr reeds since they are aluminum so you can have them opened up a bit too. fmf pipes just look shiny and arent good drag race pipes.
Team Blue: 85 Tri-z 250: under the knife
Team Red: 87 Trx250r 01Cr80 15 CBR600RR
Team Yellow: 06 Ltr450 11 Hayabusa
