Results 1 to 15 of 20
Thread: 1981 YT125 Chain Questions & 1982 Honda 250R Inquiry
    Oct 2008
    Pennslyvania
    136
    Hey guys, back for more knowledge. The chain on these '81 YT125's, how important is the tensioner on such a short chain? I opened the case of mine for inspection & it was missing. I checked eBay for one, they have a NOS one for $30 shipped, but it doesn't include the sprocket. How can I get the sprocket for the tensioner? I'm going to call my parts place tomorrow, but untill then I'll have the thoughts passing thru my mind. Also, on these beasts, is it possible to run without the chain & brake covers? From looking I think it is possible for the brake to operate without the cover, but the chain looked like the tensioner mounted into the cover, but I'd prefer to go a nude chain! But, if I can fully commit to one, I'd just leave both covers in place.
    Also, an unrelated question, I aquired a 1982 Honda 250R, the jug is bad, what is the going rate for the Hondaline 300R kits? I've searched the posts & found a few members that had a few at the time of posting, but no price listed & none are offered on eBay now. Since my jug is bad, what would my best option be for getting this one to run? I'm just feeling around, trying to decide the area I want to build this one (Restoration vs. Resto-Mod), as I'll finish the yellow one first.
    If anyone needs pictures of the chain parts, I'll have some downtime tomorrow & can take pictures then.
    I'll post a picture of the 250R because I'm that pumped about it, although I have yet to see it, I had a buddy of mine from where I grew up pick it up & store it until I can get back to the old stomping grounds.
ID:	155180Click image for larger version.
ID:	155181Click image for larger version.
ID:	155182Click image for larger version.
    Dec 2010
    Bethalto
    11
    I have a mildly ported jug from an 81' 250R it currently measures 71.93 mm. It will need a +2 over piston. Let me know if your interested.
    82' ATC 250R
    85' ATC 250R
    85' Tri-Z 250
    85' Tri-Z KX500 Powered Green Frankentrike Project
    Nov 2008
    Coon Rapids, MN
    956
    i don't run a chain cover or chain tensioner and it works just fine.
    1982 Yamaha YT125 tri-moto - Boyesen power reeds, YT175 front suspension, Headlight guard.
    1982 Yamaha YT175 tri-moto - Running but ugly
    1984 Yamaha YT 60 tri-zinger - Boyesen power reeds
    My feedback.
    http://www.3wheelerworld.com/showthr...ght=old-yellow
    My album
    http://www.3wheelerworld.com/album.php?albumid=98
    Oct 2008
    Pennslyvania
    136
    Thanks EK-Racing, I think I've about decided to go with the 480, I've actually already bought the Mugen pipe & motor mounts made by BigBore. It's time to get crazy!
    Thanks old-yellow as well, since my YT is missing all the tensioner, I think I'm going to do this as well. Do you have any of the brake cover on yours? I think if I've got the axle off, (to clean especially) I think I'll remove the plastic break cover. I just don't want to get it off & find out it's needed somehow.
    Nov 2008
    Coon Rapids, MN
    956
    I do have a plastic brake cover on mine but you don't need it to make the break function or anything else. What no pics of the YT125?
    My feedback.
    My album
    Oct 2008
    Pennslyvania
    136
    Here's the latest, I've got the pastics fairly well polished out. No pictures of this yet. Waiting on an air filter still, so I haven't bothered putting gas/oil in carb & remounting. I want to make sure it runs good before I get too much money invested in the look good. But I work at Sherwin Williams, so I thought I should go ahead & paint it & get rid of the previous owners camo job. So far, all I've got together is the first picture. The second picture is where I started. Hopefully, in another week or two at the latest, I'll have time to button it all together. Although, my light bulb on the oil sensor is blown, do you know where I can get a replacement? My local parts shop would have to order the whole new assembly, but I'm thinking I'll go to carquest & get a light set up that works & splice it in.
Name:	2012-10-03 16.08.15.jpg
ID:	155412 Click image for larger version.
Name:	2012-08-20 Day 1.jpg
    Dec 2010
    Bethalto
    11
    Cool. that 480 will run hard. I'm a fan of big bore trikes!!!
    82' ATC 250R
    85' ATC 250R
    85' Tri-Z 250
    Nov 2008
    Coon Rapids, MN
    956
    that front bracket on the front fork is a accessory as far as painting it i would strap the paint and restore the plastic. Here's a few links to doing that. http://www.3wheelerworld.com/showthr....-How-to-guide http://www.3wheeler.org/tech/fenderrefinishing.html
    bike bandit sells the bulb - number 11
    http://www.bikebandit.com/houseofmot...47095sch232494
    My feedback.
    My album
    Oct 2008
    Pennslyvania
    136
    Man, I wish I had found the plastic restoration before I did Chainsaw's wet-sand/car buff method. Even still, the plastics still look 100% better than when I started, I just have a few spots to start over with the 220 to 320 to 400 to 600 to 800 to 1000 to, well you get the idea. That's why its been a 2 week project. I guess these things are a labor of love to make pretty!
    Oct 2008
    Pennslyvania
    136
    I took finally got some time to take off my chain cover & got to thinking, if the chain breaks, I'll need a case saver. I'm thinking of hacking my chain cover & fabing up a case saver for the Tri Moto. Has anyone else done this? I have a pretty good idea of the area I'm going to go, but pictures of others are always nice starting points. Even though I had already removed the axle, getting the old covers off it really gave the old stud duck a more sportier look!
    Here's looking to you my old yellow mentor! Thanks for all your help!
    Nov 2008
    Coon Rapids, MN
    956
    I never done it myself but give it a shot and on another note check this thread out. http://www.3wheelerworld.com/showthr...ht=pro+tec+175
    My feedback.
    My album
    Trailpros
    Oct 2008
    Pennslyvania
    136
    I read the entire post, very interresting stuff. What's up with the Project TriMoto? Did someone make a hi performance yt? That's an idea I can stand behind. Also, I guess the TrailPros are just a popular tire that have a following? I noticed that my tires are Trailpros after fabiodriven's post, but I think I might be in the market for a new front, since mine won't hold air for long. I did order rear bearings, front sprocket, chain, oil light & head light bulb today, so with a weekend of work & a freshly pressure washed frame/motor/front tire at work, it looks like the time to reassemble everything else is at hand.
    Oct 2008
    Pennslyvania
    136
    Got the old Stud Duck running today, for a while. Even though I dont have a back axle, or chain, or air filter for that matter. Before I got it running, I put in about a quart of 40:1 premix in the tank, & primed the carb with 40:1. I couldn't prime the oil injector because 2 of the bolts were rounded out, hence the generous premix. Of course it smoked like a train once it ran, but it did good. Before the carb seemed to almost "hang up" after letting off of the throttle, this made for no engine braking while riding, it is why I rebuilt the carb. I only replaced the O-ring on the big adjustment screw, since it was the only on messed up, all the others appeared fine. The second time I cranked the engine, it ran fine, still had the hanging throttle, so I adjusted the small adjustment screw a little to closer to 1.5 turns out from bottom, did fine, sounded sharper but the revs still hung once I let off the throttle. Once I turned it off, gas started flowing out of the overflow on the bowl, I turned off the petcock & tapped carefully on the bowl to get the float to turn loose, it stopped leaking once I turned the petcock back on. I did the same thing, trying to adjust a little on the big screw but when I did the motor just seemed to take off & rev pretty high, so I covered the butterfly with my hand to see if putting a little resistance would calm the motor down, like a simulated air filter & box would, it seemed to help, but my hand got covered with gas, so maybe I still have carb issues? Then this black oil started dripping from my exhaust pipe. I know I was running very oily, as by then my injection had appeared to prime itself, since I had replaced the hose running from the injector area to the carb, so should I drain the premix & switch to only pure gas now? Here's a picture of the oil coming from the pipe, & a picture of a hose that I assume is a crank vent, am I right? Any suggestions on the hanging revs? Obviously having a air filter would be more ideal to have on while trying to tune the carb, surely it won't cause the motor to just rev high like that.
    Thanks again for helping a 2 stroke newbie!
ID:	155714Click image for larger version.
    Nov 2008
    Coon Rapids, MN
    956
    don't worry about the carburetor spraying gas on your hand and as for it revving up that should stop as soon as you get the air box on if not i would check for an air leak. i would run premix and block off the oil injection but if you trust the oil pump then drain the tank and put only straight gas. that is just a crank vent put a longer hose on it and put the end up high so it can't get water in it and by the way your missing the silencer for the exhaust.
    My feedback.
    My album
