atc250r stator/lights
What is the watts on the light side of the stator putting out (or able to handle) on an 85/86 atc250r?
manual states 159W @ 5000 rpm. lights are 55/60w for the headlight and 5w for the tail light
Elaborating on Falloutboys post, Low beam uses 55w but high beam uses both filaments plus the 5w tail light bulb (60+55+5 =120 watts) with 39w remaining capacity on the lighting coil. Whatever light configuration you go with, don't exceed 159w total.
Good deal, walmart sells some fake trail tech (driving lights) that are 55w each got a couple friends that have been running them on banshees without any trouble, just wanted to make sure the 250's stator could handle it
//ArrowChat Integreation Code
