Results 1 to 10 of 10
Thread: Spark Plugs
    Winnipeg
    211
    Spark Plugs
    What are the best plugs you have found for the various models?
    Ive ran a BR8ES.. and also heard DR8ES works well also
    Oct 2008
    NB, Canada
    852
    I run the champion plug in all my honda 200/185's, RA6HC.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    Mar 2007
    Texas
    5,045
    i only run NGK an any motor and i use the BR8ES ones only. there si a race plug that is simular dimensios and has a larger copper core, but they are liek $6.5+ each plug and do not last that long.
    ________________
    https://www.mikesatvfix.com
    ontario
    1,131
    I run NGK in most of my toys. My 200x and my car will only run right with an E3 for some reason
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    May 2012
    I run NGK iridium plugs in my 08 trx450 (IFR8H11) and I have some for my z's (BR8EIX) when they get finished
    Winnipeg
    211
    NGK sent me info on plugs for Honda 3 Wheelers
    NGK CR7HSA =
    1982-1985 ATC 70
    NGK DR8HS =
    1982-1985 ATC 110
    NGK DR8EA =
    1980 185
    1981 185S
    1981 ATC 200
    NGK DR8ES-L =
    1984 BIG RED 200ES
    1984-1987 ATC 125M
    1982-1983 ATC 185S
    1982-1983 ATC 200
    1982-1983 BIG RED 200E
    1984-1985 200M
    1984-1986 200S
    1983-1987 200X
    Dec 2009
    illinois
    1,765
    I just posted this question last week and most everyone including me prefer NGK spark plugs. I am sure Honda done alot of testing before they chose this plug for their machines. I've always had good luck with NGK.
    Winnipeg
    211
    yup seen your post but didnt see any PART #'s.. hope my post helps others, as I was lookin for part numbers!
    MN
    3,263
    NGK all the way... I have tried others to replace them, basically because the one local auto parts store didn't carry NGK. I tried the champion equivalent, as well as the autolite, they don't last long and seem to cause stumbling and misfires at higher throttle speeds, just don't run as smoothly.
    I found the local Runnings Farm Supply store has the NGK and they are fairly cheap so i bought a handful.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Maine
    463
    NGK D7ea in my 1983 ytm 200k.
    Current Trikes
    2 1985 Honda 250sx
    1985 Big Red
    2 1983 YTM 200k's. 1 for parts.
    KLT 250 Prairie
    1982 Honda 185 - Waiting to be saved
    1985 125m Parts Machine
    Still on the hunt for a 1986 350x and 250r.
