changing trans oil on 85r, can i use 85wt oil? i have some laying on the shelf just seeing if its ok to use?
85wt as in 85 weight gear oil? Straight 85wt? I don't think that would be too good to use, unless it's an 85wt oil designed for use with motorcycles and ATV's. If you're talking about regular gear oil for a rear end or something I wouldn't recommend it. Even an 85wt motorcycle oil designed just for two stroke trannies wouldn't be great unless it were over 75 degrees.
its maxima 85wt transmission oil for atv, motorcycles
if not good then whats recommended?
Maxima. That's a bike oil. You should be OK to use it but I'd change it out for something thinner as it gets colder out.
^^^AGREE!^^^
In the Honda service manual, they call for 10w-40 in the transmission.. Just keep that in mind. Your 85w will probably be fine for hot summertime riding, but I wouldn't run it in cold temps.... That stuff will be thick as honey down below 30 or 40 degrees.... Gonna take a long time to get it warmed up and thinned down a bit.
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 200ES Big Red
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
ok thanks for the input guys, ive never really looked into trans lube..what kind of 10w-40 should i use? isnt that just regular car oil?
You will get many diverse opinions on that question.
What I run is Valvoline ATV 10w-40. States that it is "designed for use with wet clutches" on the back of the bottle. Any other 10w-40 labeled for use in motorcycles will be fine. I hear-tell that modern conventional motor oils have different friction reducing additives that can cause premature wear on clutches.
Yes, the motorcycle safe oils are more expensive, but it's not a big deal to me since my R tranny only takes a little over half a qt.
Again, alot of varying points of view. In fact, I know there are some here that run plain ol' automotive oil and have had no issues. Not trying to start another oil thread here, just offering up what I use (with zero issues) and my reasoning behind it.
I would run ATF with no qualms before using standard automotive oil...
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
thank you!
I only use ( Honda HP Trans Oil 80w/85w aka Red Bottle ) on all my 250R's - Warm or Cold temp's no problems !
Yes your Maxima oil 85w will work just fine. always double check make sure it's wet clutch safe!
If you have Bought a item from me, Please leave me feedback
If your buying a item from me check my feedback
Click on link ~ http://www.3wheelerworld.com/showthr...ceaserthethird
i only really ride in cold temps (ice riding)
