Hi, I have a '85 250es that I think needs the one way clutch replaced.
It will engage a real kick start one out of 7 times, the other times I just hear something spin.
I have not noticed the whirling and click sound when motor is turned off or the down hill costing thing but then again it has been a while and I will need to check for them (I do not doubt they will be there now that I know what to pay attention to). The starter works but I do not bother with a battery because it kicks over EZ when it engages.
Anyway I am OK mechanically but by no means a gear-head so was hoping for some strait forward advice on how to replace this. Just not wanting to start this and run into something unexpected.
I have the manual and can see how to take off the right side cover but then it gits into things I do not think I need to do. ...then later talks about the one way clutch. So I got a bit lost.
I guess I need to know what I will need to buy.
So far I am thinking: one way clutch, right side case gasket, new oil and filter, anything else?
Also will I need any special tools?
Is there anything I should be looking for while in there if something else is worn (what and how to check).
Is there anything else I should service while in there. (I saw that the oil filter screen which I will pull and clean).
Will I need to adjust the clutch when I am done?
I guess I am just looking for the tips you would offer someone doing this for the first time.
Any and all advice and/or warnings will be appreciated.
… or just a kick in the butt (I do tend to over think)
Thanks,
Jake
