So I've searched the forum and found all the info I need about the type of oil and weight/amount, but I can't find anything about how to ONLY change the oil and not the seals, etc.
I'm not a mechanic and have limited time. The rebound isn't sounding right and I suspect that the original oil is in there. The machine is a low hour gem too!
I know I can drain the oil via the Allen bolts at the bottom, but how do you add oil? Through top bolts? Flip the machine on its ass and go that route?
Thanks in advance!
