Results 1 to 15 of 23
Thread: I need help!! PLEASE HELP pull start wont pull on 1984 110 atc
    Aug 2012
    golden valley
    20
    I try to pull and it wont, so i took off the pull start and its not that! And the neutral with the arrow is in gear when its on that! and its was ridding great before and my cousin rode it and then he said it made a noise, and stopped. tomarro i will have someone pull me and ill try to get it to start in 3rd gear but i don't want to mess it up! So please help me! Any anwsers
    Pacific NW
    4,255
    so the red ine on the shift indicator IS?
    pointing towards neutral but it feels like it's in gear?
    I know those indicators are available as replacements so maybe it got
    twisted around.
    Try rocking the trike back and forth (NOT running) and keep popping up
    on the shift lever.
    You really should try to find neutral before you start it.
    Have you tried the search key?
    Aug 2012
    golden valley
    20
    no, its like the pull rope is stuck but it is fine like it wont turn the engine, when its in neutral it seems like it should be in fourth with the red thing pointing away from the n! I cant even start it! The tires wont turn! I might try and have someone pull me tomarro but ill try and get it to the right neutral before i do that. and what is the search key!
    Pacific NW
    4,255
    Quote Originally Posted by drewshane95 View Post
    There's a box on here that you type in hot topics to search for.
    Ya know? I had a 90 that came back stuck, completely stuck and I thought the gearbox was toasted. would move, wouldn't roll, pull rope wouldn't pull..........
    turns out one of the kids SLAMMED on the brakes and locked up the rear axle.
    Brakes were completely stuck locked...AND it was stuck in 4th because we couldn't wiggle it enough to get the wheels to move so we could shift it., if that makes sense.
    Can you rock it back an forth at all?
    do the rear wheels move at all?
    oh, also click on the following words.
    service manual
    good luck and keep us posted.
    we'll get it figured out for sure.
    ps
    had a thought.
    If your hi lo lever works, you may be able to get it into between hi and lo range gears
    so the engine is essentially disconnected from the drive chain.
    if it still won't roll, I bet the brakes are jam stuck.
    Either disconnect or loosen the brake lever and cable down by the rear axle and try hitting the brake activating lever opposit of the way the brake cable pulls to tighten it.
    Aug 2012
    golden valley
    20
    no. when its in neutral it rolls but its not faceing the n, then when its in it its on the other side of the n that's when it in neutral. Its not the breaks because it rolls in neutral.
    Pacific NW
    4,255
    ok so the shifter only moves the indicator 180 degrees off the "N"?
    or feels like neutral but the indicator points away from the "N"?
    Not real common but there's a 9 dollar part called a 'shift drum stopper'
    (a good choice for your search key)
    They can come loose, bend and cause a mystery shifter.
    It's a little arm with a roller on it that indexes or positions
    the shift drum into specific areas like 1,2,3 or 4.
    I think we better wait for some more opinions or go ahead and try the search key.
    It's been quite a while since I've had one of those apart.
    You might be in a 'false' neutral, kinda in between gears.
    Even with a bad shift drum stopper, you should be able to
    rock and wiggle and roll and pull up on the shifter to get the indicator to rotate.
    But again, I've honestly forgotten more than I ever knew.
    Wonder where everyone else is?
    Aug 2012
    golden valley
    20
    Ya seriously I appreciate the help that you gave me tho! And i was doing research and thought thats my problem. well wont i need a special tool to open up the caseing to get to the shift drum stopper!
    Sounds like you locked up the motor to me. Good luck.
    Pacific NW
    4,255
    thanks fab
    As you can see, not so easy to determine what's wrong.
    soooo?
    the engine will not turn at all? is the question.?
    sounds like to took the pull start off and the pull start turns off the trike by itself but will not turn the engine?
    Can you turn the engine by hand with the pull start off?
    Aug 2012
    golden valley
    20
    No, It will not turn at all! Its like it is jammed! should i have someone pull me to try to start it? And the rope works great when i took it off it was pulling fine! I was thinking its the shift drum stopper?
    Aug 2012
    golden valley
    20
    Can i try to loosen it up by putting oil in the plug hole?
    Pacific NW
    4,255
    ok,
    Let's start over.
    Don't worry about the shifting or shift drum for the moment.
    We need to figure out why the engine won't turn.
    The pull start is off and you see a basket type thing bolted to the engine
    that the pull start pulls on and rotates the engine, right?
    If you cross that 'basket' with a broom handle, you say the engine won't turn either direction
    AT ALL?
    not even the distance like a loose, but locked door knob?
    If that's the case, you can easily pull the spark plug and certainly try to look down inside the cylinder.
    Can you get a better story from your cousin ?
    Maybe a few more details like it ran good, then crappy and then made noise and it got louder and then a big klunk and it stopped in it's tracks?
    is there any oil in the engine?
    Aug 2012
    golden valley
    20
    yes the bascket rotates the engine, Will not turn either direction, it will turn bearly, like a quarter inch sometimes. I pulled the sparkplug i looked in the cylinder but its hard to see threw that tiny hole! what i seen was drity metal. do you mean open it up? My cousin is a piece of , he took off right after it happend!
    Aug 2012
    golden valley
    20
    ok soo i pulled my bike and poped the engine free but now i have no compression? why?
    glendive, montana
    1,822
    your cousin prolly snapped a ring, I wouldn't try to start it anymore for fear of further damaging the cylinder or or anything else. It is now time to tear down the top end, if you are lucky you will only have to bore .010 over and get a new piston. If you are unlucky you will have to get a new .050 over piston and have it bored to that, it all depends how bad it is gouged inside. I wish I would have seen this earlier as I would have told you not to try and pull it. first thought that came to my mind when you said it wouldn't turn over but the pull start was fully functional was that you seized the motor. Don't fret, this is more common than you think and there are alot of parts out there for your trike, so the cost won't be outrageous. Here is a link to a manual for you http://www.oscarmayer.net/atc/manuals/ good luck
