Thread: 200x engine swap jetting issue, help needed
    Aug 2011
    Bangor Saskatchewan, Canada
    91
    I've recently put a 1982 Honda atc 200 engine in an '84 200x, but in order for it to fit I had to remove the carb insulator (the intake spacer between the head & carb), now it won't run, it fires but won't start, so I am assuming the carb needs to be re-jetted now that the insulator is missing. So my question is would I have to jet it leaner or richer? does moving the carb closer to the head make an engine run richer or leaner?? & would I use a bigger or smaller needle jet to fix this problem?
    ~ 3 WHeeLeRs 4 LIFe! ~
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    How did you get the carb connected to the engine if you removed the intake boot? Is there something I'm missing?
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
    Aug 2011
    91
    There are 4 holes for bolts in the head, the carb just bolted right up.
    Scootertrash's Avatar
    In the sticks
    4,638
    Quote Originally Posted by ailll1 View Post
    This. ailll1: Do you mean the intake manifold? To me the boot is what goes from the carb to the airbox
    kormos: Got a couple of pics? Sounds like you are trying to eliminate the intake manifold. You can't do that. The manifold is where the fuel and air start to mix on the way to the head.
    You'll need a 200X manifold for the carb to fit
    Southern MN
    1,875
    Scootertrash is right, you need to use a 200x maniold, it comes out at a different angle than the 185/200s and the carb will not hit the frame. Good luck!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Aug 2011
    91
    O.K, thanks scootertrash & yamaha_rules. I guess I will have to find an intake manifold from a 200x (the trike had no motor when I got it) so I just assumed I could eliminate the manifold & make it work with a bit of re-jetting. Since I have never seen an intact 200x motor & have no idea how the stock manifold angles to avoid the frame.
