Results 1 to 8 of 8
Thread: Whats up with this main jet situation?????
    May 2003
    Houston, Texas
    2,409
    Took my carb apart and there was a 320 main jet in the Tri Z. I learned that a 470 is stock.
    My plug was oily black at 320 so I:
    cleaned my air filter and installed a 310. Now the plug is tannish, mocha brown.
    The only mods on this Z that I know of are:
    1) Boyessen reeds
    2) DG silencer (no pipe)
    3) open airbox lid and K and N filter
    Whats going on here guys??
    I don't want this thing to detonate!!
    Darius (man the troubles never cease!)
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    Watertown, New York 13601
    3,382
    470 is not the main jet for all tri-z's 470 is the right main jet for the tri-z (N) it says it on the front of the frame. The tri-z (S) main jet is 360 i think.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,250
    DO YOU HAVE KEIHEN JETS IN YOUR MIKUNI???? i know that they look the same and #'S ARE WAY DIFFERENT ,,,, maybe?
    May 2003
    Houston, Texas
    2,409
    Last night I went to bed thinking that the 86 must have come stock with a smaller main jet.
    I just need to look at my manual and don't have it here.
    Thanks guys...sorry for creating a crisis every 5 minutes!!
    darius
    Dirtbikes:
    1988 Yamaha DT
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    Yeah the 86's (s) models had different carb settings, 360 main I think. I dont know why the 85's had a 470 (mine has 470), what could be so different about the engines that you would need a radical main jet change like that?
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    May 2003
    Houston, Texas
    2,409
    The motors have different porting. Denn is gong to compare the 85 and 86 cylnders. There is a difference in the power of the two bikes. In 86 Yamaha made some improvements. I don't think the 86 has the wrench report mods on it...but Yamaha may have done a few things to give it more power.
    After all if they knew how to do it with the wrench report and recognized it was a problem...why would they just leave the 86 alone?
    Darius
    Dirtbikes:
    1988 Yamaha DT
    Central PA
    1,952
    I thought that porting didnt affect your carb settings?
    PastRides
    SOON MY PRECIOUS!
    May 2003
    Houston, Texas
    2,409
    You are probably right. I am not the carb expert. I know that the 86 has a bigger intake boot that mounts on the carb.
    Who knows....as long as I am not going way out of the ballpark. My plug looks good too!
    Dirtbikes:
    1988 Yamaha DT
