Here is a fun story for you guys on this. Found a 1986 350x on craigs list for $250 non-running, so I called the guy on it and got the low down on it, he says it is in ruff shape and the back story on how it quit running. Basically he had law issues with an officer that didn't know the law. After things cleared up, he went to start it and it wouldn't start. Anyway, I shot up there right away to look at it with my uncle. Well he was right, poor shape, worn out bearings, stainless steal airbox cover, exhaust welded on (extremely poorly), font tire I can nearly see the air in, etc. I messed around kicking the engine over a little with the switch off to check compression (decompression cable missing) and it didn't feel like much there. I noticed the tank was plastic.... and looked inside.... hmmm nearly bone dry. So I pay the man, write up a bill of sale, got it loaded, and used the tip trick to get a little gas in the carb and kicked her with the switch on. It fired right up and was idling perfect, so I reved it expecting it to run lean and pop some so it didn't sound so good... yea it reved pretty cleanly too. The guy didn't really say much except that it looks like I fixed it lol. Kind of feel bad firing it up right infront of him like that, I just wanted to get a good pop out of it since I was excited to finally get a 350x. I'm thinking it felt like it didn't have compression from the lefter sticking or something, now I can stand on it on the compression stroke and it holds me for a few seconds.
Anyways... the parts list I need. I'm kind of tossed up between fixing it up fairly well, or fixing it "good enough". Either way it is a rider and already had it buck me off and I hit my tail bone. 350x is a world of difference comming from the shaft drive family (250es, 200es, 250sx), and even in it's poor shape has more power than my 350 warrior had... I think overall it is a good buy, but too much to really fix up nice. I'm keeping my eye out for another one in my area, and if I find one, I'll probably put this one down as a parts machine.
Things I will 100% need
Full rear brake system (master, slave, lines, pads, and mounting bolts needed)
exhaust pipe (full pipe, wouldn't mind getting a cobra if the price is right) - current one is welded + has huge leaks in the header pipe
Might need a head (exhaust pipe is welded to the bolts that hold it on, so hopefuly not, but it is leaking there too)
Things I might be interested in
engine mount bolts (i have spares from a 250x quad, not sure if they will work, but heard they might)
front brake reservoir (might have one that will work from my parts 250x)
Front tire - factory size is 23.5 x 8 x 11 (if i remember correctly), the tire on it is 23 tall and 11 for the rim. I'm watching for a fair priced 23-34 inch tire that will fit.
case saver
Stuff I already bought, if your interested in knowing...
front shocks/forks (ebay set + rebuild kit)
air box lid (bought full box + tubes via ebay special)
Full headlight assembly (I have one good headlight, other is damaged as well as the plastic broken pretty bad. Rubber Hold-ons are good) - I might just make a fog light work (27w led)
rear axel bearings (nuts were loose when I got it, still has a bit of play)
front hub bearings
And here is the long list of small issues it will still have....
Compression release cable missing
Clutch appears to be nearly worn out (lever is nearly pointing stright back)
Left engine case cover has chain damage + a poor man's rtv fix and is leaking slowly
Lights currently don't get power to them, have to look into the cause yet, hopefully just a fuse/disconnected wire
Rear plastics are "ok" but do have a couple of spots that are broken, I think where they are supported.
Seat is a duct tape special
Rear grab bar is custom made, but is too short to be useful
