Results 1 to 15 of 16
Thread: Removing the labels/stickers on new tires
    Scootertrash's Avatar
    In the sticks
    4,638
    I have a set of new Bear Claws and would like to remove the label or sticker that has the yellow lettering on it. See pic below, I can post a better pic if you want. Has anyone ever done this? I have a ton of ideas: heat gun, goof off, acetone, lacquer thinner, etc, but I'm just curious if anyone else has tried it and if they were successful, what worked.
    Apr 2012
    USA
    4,129
    I think it is painted on, so something that removes paint should work but not sure what the effect would be on the rubber.
    In the sticks
    4,638
    It looks more like a sticker. This isn't on the tire lettering. I'll take a pic once the sun comes up and post it.
    Cave Rider's Avatar
    Cave Rider is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Howes Cave NY
    320
    Carb clean...
    Pacific NW
    4,255
    Tire cleaner sounds safe but may do nothing except lighten your wallet.
    How was the price on those btw?
    rjs89ia's Avatar
    rjs89ia is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2010
    Kingman, AZ
    271
    see if you can locate some (M.E.K. / methyl ethyl ketone) at your local hardware store we use it on planes for removing just about anything with adhesive and more.
    Deathrocket's Avatar
    Deathrocket is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Assachusetts!
    349
    why not just mild soap and a brush... stuff doesn't stick too well to rubber from what i have found...
    In the sticks
    4,638
    Quote Originally Posted by tri again View Post
    I got my 22x12-8 for 117.50 shipped for the pair
    I have some MEK out in the shop, I may give that a try.
    ETA: Here is a pic of the actual sticker. It almost looks like an iron-on clear label:
Name:	Bear Claw  label.jpg
    Las Vegas, NV.
    2,538
    If none of the above ideas work, have your wife or girlfriend try to parallel park it next to the curb. And presto, they'll be scraped right off.
    CAUTION: Use sparingly, as your rims may get gouged as well.
    North Dakota
    1,643
    Looks like its painted on to me.
    Mar 2012
    scotland
    29
    where did u get those tyres from as im looking for a set for the bak off my 200x
    Oct 2007
    Minneapolis mn
    4,067
    I would try wiping them off with a bit of laquer thinner... MEK is some pretty nasty stuff, would worry about it trashing the rubber
    Jun 2003
    Anchorage/Homer, Alaska
    480
    I've had my Bear Claws about five years now. The yellow letters are created by a black cutout put on top of a yellow bar. I have no idea what either is made of. After all the rough riding I have done with these tires the black part has worn away and only the yellow bar remains. It is starting to wear through the yellow part where the letters were.
    Be very careful with MEK and use the proper PPE. Be aware that it is flammable. From the MSDS; "Hazardous in case of skin contact (irritant, permeator), of eye contact (irritant), of ingestion, of inhalation (lung irritant)... The substance may be toxic to gastrointestinal tract, upper respiratory tract, skin, eyes, central nervous system (CNS). Repeated or prolonged exposure to the substance can produce target organs damage"
    http://www.sciencelab.com/msds.php?msdsId=9927358
    1985 ATC 250ES, Big Red
    1984 ATC 125M's, 1.5 of 'em
    1983 ATC 110, BLUE!
    1974 ATC 70 Pink?
    Pacific NW
    4,255
    117 shipped?
    May I ask from where?
    I need some too.
    Thanks
    Eastern Long Island
    1,688
    Mount them on opposite sides so the letters are facing in. No nasty chemicals needed.
    Lots O Trikes!!!!!
