Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Thread: The tri zinger.
    spentar is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2012
    buffalo, ny
    217
    The tri zinger.
    Winters coming and the zinger will be my project. I want to make it faster, ive already eliminated the oil injection to premix, i bought an air filter to replace the airbox, and thats about it. I have a dg pipe that im getting in less than a week too. Im planning on getting an oil injection block off plate to eliminate the internal gear, which ive heard will possibly make the bike rev faster. But what else can i do to give me the edge? ive heard of the yamahopper 2 speed tranny, but thats alot of work for a 15 year old kid. I know they got rid of the 70cc big bore kit, I dont know if rebuilding it would help it rev higher or pull harder. But if anyone has any ideas i would like to hear.
    My Things:
    84' Tri Zinger-Blue
    2009 can-am ds450xmx
    85' Honda 350x (Its my dads but it will be mine some day I hope)
    85' Honda 250es BIG RED (My dads but it will be mine some day...)
    2002 Artic Cat z370
    Big Mike's Avatar
    Hanson, MA
    1,062
    pull the crank and have it knife edged and lightened. anything to help cut down on rotating mass will help get it to rev faster.
    Jul 2012
    Seattle, Washington
    1,543
    I'm in the process of building my tri zinger too.
    You can buy Boysen Power Reeds, bore the piston up the next size or buy a new top end kit :
    http://item.mobileweb.ebay.com/viewi...id=96962721068
    There's got to be other tricks to getting a little more out of the tri zingers! I'm going to swap my tires off my alt 50, was thinking about pulling the gas tank and carb from my Suzuki mini quad just to play around with it. I also ordered those large foot pegs from the 3ww shop.
    x2 on boring the piston. I've had great results with that.
    Dec 2010
    S.E. Illinois
    1,178
    you've just about covered it i think. not too much you can do with the zingers without opening them up for internal mods.
    74 HONDA ATC 70
    Jul 2012
    Seattle, Washington
    1,543
    Quote Originally Posted by Jon Boy View Post
    What are the internal mods? I'd like to hear about these mods and what kind of results do you get out of them?
    Thanks!
    Nov 2011
    New york
    115
    NO! do not buy a after market knock off kit. I purchased a kit from the people in your link earlier this summer, the kit was complete crap. I was getting only 60psi for compression.
    TRUST me on this your way better off getting oem even though it costs alot more. Just forewarning you.
    Quote Originally Posted by 3 Wheel Drive View Post
    http://item.mobileweb.ebay.com/viewitem?itemId=221120827900&index=0&nav=SEARCH&ni d=96962721068
    Quads:
    2004 Ltz-400
    2012 Ltz-400
    Trikes:
    85 ATC 250r
    85 Tecate
    82 Tri-moto 125(The wheelie machine)
    85 ATC 70
    85 ATC 110
    84 Zinger
    Bikes:
    03 Rm 60
    Sleds:
    05 f5 Firecat
    78 Lynx 275
    Jul 2012
    buffalo, ny
    217
    Also to the fact that russ98atc's zinger blew up today with the knock off kit. Thats only a couple months old. And i assure you he was mixing to the correct spec and did nothing wrong to make it blow up.
    My Things:
    84' Tri Zinger-Blue
    2002 Artic Cat z370
    Nov 2011
    New york
    115
    Quote Originally Posted by spentar View Post
    It was broken in properly and taken care of well. Granted yes i did run the piss out of it this summer till now, but it showed poor performance from the start
    Quads:
    2004 Ltz-400
    2012 Ltz-400
    Trikes:
    85 ATC 250r
    85 Tecate
    85 ATC 70
    85 ATC 110
    84 Zinger
    Bikes:
    03 Rm 60
    Sleds:
    05 f5 Firecat
    78 Lynx 275
    Jul 2012
    Penfield NY
    660
    When you get that let me know. I'd like to check it out and see how it goes in as I'd also like to get rid of the pump.
    We'll be in Sat Spencer so I'll grab Russ and we can head over to your place with the pipe.
    Yeah Russ it didn't seem to run right at all. We're just keeping Con's zinger stock. We bought the wheel adapters that will get us to 3/120 so
    we can get some real rims and tires on it, but that is about it....other than a new carb.
    This winter we are concentrating on redoing my LT250S. Found a powder coater and should have new plastics for it
    this next week.
    May 2007
    Orange County, NY !
    1,673
    I want to know more about this yamahopper two speed tranny mod?
    bandito90's Avatar
    bandito90 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Pa
    284
    @riverrat it's a two speed automatic that came on the SG50 Sting,LC50 champ and MJ50 towny.Not sure what needs to be modified to put in a zinger frame.
    1978 bandito framed atc90
    1984 YT60
    1974 rd60
    2002 Buell Blast
    1984 Honda xr100 project in the trunk of my car.
    1964 honda C100
    1981 Honda Hobbit
    1984 Yamahopper
    Quote Originally Posted by riverrat View Post
    I'd like to know a little more about this mod as well. I rode Andy's (crazy70man) 2-speed Zinger in the drags at Trikefest '12 and the shifting is absolutely great. The only problem with the setup is the gearing is too tall, as Andy has mentioned in other threads. It's a bit tough to get the machine rolling from a standstill, even in first gear. Once you get going and it shifts into second, you're really rolling along at that point. As Andy said, I'm sure it approaches or even exceeds 40mph. If the gearing could be brought down a few notches it would be an absolute "must have" as far as Zinger mods go.
    OHIO
    2,857
    Here ya go Riverrat...http://www.3wheelerworld.com/showthr...t=speed+zinger John is right. The zinger will hit 40 with a 230lb adult on it without the NOS and a few more mph with it. The internals are a little involved...uses the mj50 aka Yamaha Towny moped crank, towny gears and clutches and right side towny cover as the crank is wider than stock zinger. Mine also incorporates qt50 rear gear in the rear end which I have never actually been into, just told by the great builder of it who recently passed away. The problem I beleive was that the original primary clutch for my original motor was drilled and machined to be very light. Well it was broken and repaired so I did not risk installing it. I bought a new stock clutch which was much much heavier. If I can get another clutch machined down and install some different springs.... I think it would be night and day as I have heard stories of this trike from back in the day and it is not there yet. The NOS helped but can be dangerous if you are not up to speed!! Give Raffa a shout...he re assembled my motor and did a great job. Gonna tear into it this winter and get to lack of low end. Still was cool to hear Fabio hit that NOS trigger in the drags at TF12!!
    Jul 2012
    Seattle, Washington
    1,543
    I just pulled my motor and installed the Boysen power reeds last night. I was wondering if anyone has ever made a torque reed spacer for their tri zinger?
    I'm waiting for my new foot pegs and DG exhaust to arrive before I install the motor. I was thinking about making a spacer out of some 1/8" plastic just to see what happens. My parts should be here any day.
