Hello all. I am currently working on an 85 Tri-z. When I test drove it the engine ran well,, in spurts. It would pull with full force and rev strong all the way through its rev range try to sustain a fast pace for any length of time and it would bog down.
I could pull the clutch and feather the throttle to keep it running. After a few seconds of it wanting to die it would liven right up again.
I can only assume it is one of two things a fuel delivery issue or an incorrectly set float in the carburetor.
I have read that you can take the fuel pump apart to check the diaphragm. If I do and it is not damaged will I still need to replace any gaskets? I ask because the only rebuild kit I have seen is $40. Can someone point me towards a cheaper alternative? I also found a mikuni fuel pump new on eBay for $20 free shipping. It is square and I wonder if the shape would cause any mounting concerns. Has anyone used one of these? http://item.mobileweb.ebay.com/viewi...d=280993460757
I am in the middle of splitting the case on the motor and got held up at the flywheel, so I'm trying to keep busy by trying to solve other issues while I wait for my motion pro puller to arrive.
Thank you all for previous help on my newest project and toy.
