Results 1 to 15 of 19
Thread: 350X with 2006 400ex engine swap!
    Jun 2011
    Florida
    18
    Hey guys im new to this.. I was trying to post a comment on a thread of someone wanting to know if the swap is possible but page isnt letting me.. Anyone know why? Well anyways if anyone needs info on this kind of build just ask...
    Jun 2011
    Florida
    18
    Also want to know if you guys are able to see the 5pics i uploaded thanks..
    fingerlakesny
    2,834
    where u put the oil tank ? ooppss jumped the gun... i dont see any pics..
    250r dust runner
    jdm97ek4 is offline Check My Feedback before dealing with me! Arm chair racerNew to the board
    Feb 2012
    Homer City pa
    132
    does it bolt in?
    Jun 2011
    Florida
    18
    I got a chevy van 2003 a/c drier and gutted it out and did some fittings on it made 2 brackets and bolted it to one of the upper rear engine mounts. I will try to post more pics later. Used original motor mounts just cut them and refit them.. Airbox snorkel mounted perfect on 400 carb..the DG Oval exhaust is from a 400 had to cut off a 1/4 inch of the end of header and pretty much bolts right up to frame with minor hand bending...you guys prob can see my pics in the 350x group pics...
    Jun 2011
    Florida
    18
    Also the block has a mount in rear of block that you need to drill out dont worry i already ran the risk for you guys you wont leak oil or damage anything! You need that mount to bolt bottom rear to frame with 2 flanges with tube spacers... I hope all this info helps some of you guys do the swap!
    Apr 2012
    USA
    4,133
    How about the electrical? I don't know a lot about the 400ex sadly. Should be interesting to have one on a 350x farme, or even a 250x (quad) frame with a bit more work.
    Jun 2011
    Florida
    18
    Use 400 electrical and if you run it right you wont have any extra wiring and everything falls right in place.. You will put battery where tool box use to go.. I put my voltage regulator in my 350x stock airbox my cdi goes where 350x cdi went and 400 coil where 350 coil was...
    Apr 2012
    USA
    4,133
    Sounds like if it is done right, everything will end up looking stock . Now I have to watch out for a wrecked 400ex for cheap lol.
    Jun 2011
    Florida
    18
    Mine looks stock! Try to make album later...
    MOTOMAX27's Avatar
    MOTOMAX27 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2006
    Miami, FL
    266
    Hello guys. top notch is a good friend of mine. And YES the bike looks stock and really clean.
    Jun 2011
    Florida
    18
    Album done!
    Salt Lake City, Utah
    84
    Sweet build man! I have thought alot about this conversion myself.. Maybe one day when my current project is finished..
    STL
    3,560
    i cant see pics! AHHHH! sounds like good work, where can i find the pics?
    Apr 2012
    USA
    4,133
    The Album isn't the easiest to find. here is the link for those looking for photos. http://www.3wheelerworld.com/album.php?albumid=1189
    Overall, looks to be a nice clean build thanks for sharing!
