Results 1 to 14 of 14
Thread: honda rim support patch ?? how critical?
    Oct 2012
    Upstate NY USA
    118
    Should the rim support patch always be used...???
    how critical is this part??
    i dont seem to have them...
    #5 in the drawing
    Thanks,
    Chris
    84 125m
    83 185s
    83 185s
    83 185s
    84 200es
    That looks like the valve stem to me.
    Nov 2008
    Coon Rapids, MN
    956
    looks like the valve stem to me also
    1982 Yamaha YT125 tri-moto - Boyesen power reeds, YT175 front suspension, Headlight guard.
    1982 Yamaha YT175 tri-moto - Running but ugly
    1984 Yamaha YT 60 tri-zinger - Boyesen power reeds
    My feedback.
    http://www.3wheelerworld.com/showthr...ght=old-yellow
    My album
    http://www.3wheelerworld.com/album.php?albumid=98
    Abrams, Wisconsin
    739
    i think maybe he means part#6?
    86 250sx - old reliable
    another 82 110
    -gone but not forgotten-
    82? 110 - why did i sell it??
    84 225dx - meh, it was a pile
    If he is talking about #6, I know what that part is and I've seen plenty of people run without them. That's all I know though. I don't know exactly how critical they are.
    Blossvale NY
    4,563
    Same here. I always thought those were used only on the 2-piece rims till I realized my '84 Big Red has them with it's conventional 1-piece rims. I kind of scratched my head as to why there are there myself, but I kept them in place anyway.
    My only guess is maybe those old 4x130 (or whatever they are) bolt pattern rims with their much smaller studs than the newer 4x110, those rings may be there to somehow compensate for the small studs?? That's only a guess though.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Apr 2012
    USA
    4,133
    I think Red Red is correct on this, the threads and nuts are very small compared to the 4/110 bolt pattern. I have took my 84 big red though hell and back with no problems WITH them installed. Just food for thought, maybe putting a fair side washer might do well if you ride it hard.
    Quote Originally Posted by ps2fixer:1167286
    Not if it's a counter-sunk hole or chamfered nut.
    Apr 2012
    USA
    4,133
    I know it is flat factory, I think the nuts have the barbs to act as a locking nut.
    Blossvale NY
    4,563
    Yes, my Big Red still has the OEM lug nuts and they have a barbed sort of washer surface on the inside of the nut that butts up against the rim/spacer plate.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    MN
    3,263
    They are basically reinforcement plates if nothing else, one on either side to sandwhich the wheel inbetween. If you want a set i just saw a set of four of them on ebay for like $20. Not sure how much weaker the wheel would be without them but thinking they were put there for a reason after all. My 84 200ES has them, i remember when i took the rear wheels off to put tubes in the tires i was like what the heck are these things for... LOL
    I remember seeing plates like those on some other stuff over the years and always figured they were to add strength.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Howdy's Avatar
    Celina, Ohio
    10,079
    The plates are a reinforcement to keep the rims from cracking / breaking in the middle. If you run without them you could damage the rims if you slide sideways into something. If you want to add some plates let me know. I have a few extra's at the shop. $11 shipped for 2 ( 1 rim ), $16 shipped for 4 ( 2 rims ), $21 shipped for 6 ( 3 rims ). Shipped via Priority mail.
    They made 2 different sizes, if your interested I just need to know if the rims are 8" or 9" rims ( I have both sizes ).
    Howdy
    Oct 2012
    Upstate NY USA
    118
    thanks for the comments guys... I just picked up the right size rims and tires and forgot these and didnt know if the guy had them....
    I called him back and he had them and gave them to me... I, now just need to be sure about the front to see if I have that pair
    Thanks,
    Chris
    84 125m
    83 185s
    83 185s
    83 185s
    84 200es
    Jul 2021
    USA
    Quote Originally Posted by Howdy View Post
    Howdy
    Good day. You still got those plates..i need the 4/130 bolt pattern 8" for my 125m...i would need (6) if you still got them. Thanks brother appreciate your time.
