Dudes.
I have 22 x 11 x 8 strykers on my 85 Tri Z. Any other Tri Z owners have a good input on what size is the best to get good speed and performance? i was leaning to a 20 or even a 18 inch high tire.
Tom
Dudes.
Tom
1986 Yamaha Tri Z (Restoring)
1985 Yamaha Tri Z (70% done)
1999 Harley Davidson Fat Boy
1960 Mack B 73 (restored)
i run 20x10x10 holeshots on my 85' made a big handling difference over the stock 22"oh yeah i have a +6 swingarm just to keep the front down!!!!
20' tires are great for all sport trikes.
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
i forgot,i use 15/40 sprockets
Try either ohuts or dunlop radials (20x10x9). You'll need new hubs and rims though. Any yamie sport quad other than the blaster has 4x115 hubs and use 9 inch rims, I suggest picking a set of these hubs and rims up and giving either of those tires a try.
http://photos.yahoo.com/dynofox250 (TF 03 pic's)
Trikes: Restored '86 ATC 250r, original and mint '83 185s
Quad: '86 TRX 250r
Sled: Rev X 800ho mod
Bike: '00 ZRX 1100
TF '03 and '05 Survivor
Won't the blaster rims and hubs fit right on a tri-z?
1985 YAMAHA TRI-Z 250 sold
2006 YFZ 450
18" turf tamers, make it look right.
Haspin veteran '02, '03, '04, '05
"Hey is your dash-cam on? Are we gonna be on C.O.P.S?"
RECOVERING Trikeaholic
While I agree with Holic 100% (that's what I have on my Z), I would suggest a flat profile 20" tire. I hate the "balloon" stock 22" tires on the 85. I switched to 18" turf tamers. they suit me fine, but most people say they don't give enough ground clearance for trail riding. To me personally the 22" inchers on the rear of the 85 Z and the 84/85 KXT seem too "roly-poly". The do provide a nice cushy ride for easy paced rides.
1986 Tecate
1984 Tecate
1985 Tri-Z
1986 ATC350X
1985 ATC250R (2)
1985 ATC125M (2)
1982 ATC70 - Original Owner
175 TriMoto Frame with Pro-Tec Rear Suspension
3-Wheelin' since '82
Yes blaster hubs will fit but they are the same as the Z 4x100. Blaster rims are steal, where the z used aluminum rims. You can always run 20's on the stock 8 inch rims but I liked the 9 inch rims and 20 inch fast trekkers on my 85 Z.
Quad: '86 TRX 250r
Bike: '00 ZRX 1100
I have 22" holeshots. They have a square profile and aren't real bouncy BUT I like them becuase they give me a little more ground clearance.
Your choice of tire really should be dictated by the type of riding that you do.
Get some banshee rear wheels and hubs and everything will fit perfectly.
The banshee rear tires are great...I think they are 20 x 11 x 9 or so and make sliding the Z a breeze.
I think if the 86 and 85's came stock with this set up the turning issue would be greatly dimished. Tri Z's have the most steering lock of any trike...it makes them sharp turners.
SEND ME PM HERE - CLICK HERE
Dirtbikes:
1988 Yamaha DT
Didnt the 86's come with 9 inch rims?
PastRides
Originally Posted by atctim
I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!SOON MY PRECIOUS!
yes the 86 model has 9 inch rims. These are like the banshee rims but a different spacing between the bolts. So you can't use banshee rims without changing the hubs. The hubs will slide right on the stock axle.
I just swiched hubs so I can order dune wheels and tires without any trouble.
Also I think the new 450 from Yamaha and the Raptor and the banshee all use the same hubs...Warrior too...
Opens up a world of possibility. Here is pic...still looks stock and I like the spacing around the hub better anyway...its more spaced out.
Dirtbikes:
1988 Yamaha DT
I wouldnt go smaller than 20", and personally I prefer 22" on a TriZ, unlike other trikes, because of its frame geometry, especially if you have the stock 25" front tire. It will powerslide corners a lot better if you can tilt it forward to reduce the "chopper" style weight distribution.
i like the 20" tires i just got my new MAXIS RAZR from santa (ups guy). i like the way they look and grab but i also get enough ground clearence as well as enough low end, there right there in the middle.. good luck
85 Yamaha 225 DX (Sold)
84 Honda 200s (For Sale)
83 Honda 250R (For Sale)
85 Honda 350X "If you have enough money you can buy it...
86 Honda 250R "THE KING" (Never For Sale)
